I do a fair amount of bracketing with my K5.
Originally posted by RockvilleBob I am not sure about continuous shooting, I go to Drive Mode and use Exposure Bracketing. When I use a manual cable release I get 5 shots in succession but then the 5 shot sequence begins again after a pause. When I use the IR release I need to press the button 5 times.
It sounds like you are not pushing your wired remote release button down for the entire duration of the sequence. If you do not have one push bracketing enabled - you have to push and maintain the button depressed, or it will halt (when the button is released) part of the way through the 5 frame sequence.
Originally posted by Karl Stevens Is one-push bracketing enabled? (Custom menu 9) By default it's off.
With the one push bracketing enabled - you might also encounter the opposite problem. If you press the release and are slow in releasing the button, the camera (depending upon the lighting conditions), may fire off 5 frames extremely quickly, before you have the opportunity to release the button. In that case, the camera will initiate another sequence of 5 frames.
I might suggest that you go from 1 ev stop to 2 ev stops between frames. The sensor in the K5 is so good, you might as well capture all the dynamic range that is available to it. I got in the habit with my K20 of using 1 ev between frames in order to limit the sensor noise. No need for this with the K5.
