07-25-2012, 07:33 AM   #1
Earl53's Avatar
Can Sensor's move?
Here's my problem. I have a K10D and I use my tripod a lot for panoramic shots. I level out the tripod and when I look through the viewfinder it looks level but when I get them on my computer it's tilted. I think it's getting worse and now I'm finding that when I magnify the photo to see the pixels it looks like some are missing and I see white pixels where there shouldn't be any. I use the clean sensor function so every time I turn the camera on I get the clunking sound. Could my sensor have shaken lose or have done damage to the sensor by using that function? I need to send it out to have it checked and soon.
07-25-2012, 07:41 AM   #2
Not a Number's Avatar
When I eyeball it with my K10D it the results are often off-kilter. When I use the spirit levels on my tripod the horizon comes out as it should. Try that first. And yes the sensor does move - for dust removal. You can buy spirit levels that slip into the flash hot shoe.
07-25-2012, 07:55 AM   #3
Earl53's Avatar
I'll try that first, thanks.
07-25-2012, 07:57 AM   #4
Docrwm's Avatar
Also you might want to turn on the remote because it turns off the shake reduction. You really do not need the SR turned on if you are using a tripod. That may help as well.
07-25-2012, 03:06 PM   #5
After a year or so in service my K-x developed an internal 'tilt'
as described in 1st post, despite holding the camera level thru viewfinder,
the recorded images were all 1-2 degrees tilted to the right.
Warranty repair thru Pentax Canada, loose sensor or something.
Lately I think it's starting to do it again, not as severe maybe 0.5-1 degrees,
but after 2 years of hard use/being banged around I'm not going to spend to get it fixed out of warranty.
function, level, pentax help, pixels, sensor, tripod
Difference Between Full Frame (35mm) Sensor & Cropped (APS-C) Sensor richard balonglong Photographic Industry and Professionals 22 06-28-2012 02:20 AM
Looking to move up to A K 5 offshore5 Pentax K-5 6 12-28-2011 07:57 PM
People The way we move SilentLight Post Your Photos! 6 04-24-2011 06:10 PM
Macro On the Move eaglem Post Your Photos! 3 08-08-2010 11:59 AM
Did I move the sensor??? Keebler Pentax DSLR Discussion 7 02-05-2008 05:48 PM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
