07-30-2012, 03:51 PM   #16
tweet25's Avatar
QuoteOriginally posted by Philoslothical Quote
It's unlikely that the memory card has anything to do with it. From what you describe, it sounds like a white balance issue. Is it set on AWB?
yes it is i double checked that.
07-30-2012, 06:11 PM   #17
Marc Sabatella's Avatar
Is your monitor calibrated? Maybe the camera is fine and your computer is off. Anyhow, all we can do is guess unless you post some pictures, preferably with Exif intact.
07-30-2012, 08:38 PM   #18
Just1MoreDave's Avatar
When I got a new camera, Adobe Camera RAW was the problem. Their profile was much different than I was used to.This would only be your problem if you're shooting RAW and your RAW converter is using an unusual/incorrect profile for your camera.
07-30-2012, 09:16 PM   #19
tweet25's Avatar
Hi - this is the 35th photo I took with it, the car is so not that colour. (it is like a soft barbie pink -in this photo the pink is so bright you can't really see the flowers) I had it set to JPEG only the EXIF is attached. any help you guys can give me would be really appreciated. (I have tried adjusting the ISO so it can't go past 200, I don't know if that helped or if I am desperate to see an improvement) thanks
PENTAX K-30  Photo
07-30-2012, 09:30 PM   #20
tweet25's Avatar
I Posted a pic - and i thought about the monitor - but my photos from the Kr look fine, I emailed the pink car photos to work... boohoo! they look horrible there too.
07-30-2012, 09:56 PM   #21
Philoslothical's Avatar
It does look like too much magenta in that shot. Well, if you're shooting jpeg, check the custom image settings. The default on the K-r is "bright" which I didn't much care for, preferring the "natural" setting on the odd occasion I shoot in jpeg. Perhaps something is changed in those settings, or perhaps the K-30 is just different in its defaults, I don't really know as I haven't had an opportunity to use one.
Also, what kind of results do you get if you shoot raw?
08-01-2012, 07:11 AM   #22
tweet25's Avatar
I used Lightroom and pulled back the magenta and made a few other adjustments and the shots look better as far as the colour goes. (thank you) the Raw photos seem to be a little better for colour- but I have not had a chance to take more photos of the pink car. I played with the white balance settings on the camera and still most shots seem 'bright'. I am puzzled, I hope I didn't get a dud. thanks again!
08-02-2012, 02:23 AM   #23
In addition to WB there is also the custom image settings (mentioned previously) that could be affecting your photo. Try setting it to natural as suggested. This is the menu where you pick from landscape, portrait, bright, natural, vibrant, etc...
08-02-2012, 07:22 AM   #24
tweet25's Avatar
QuoteOriginally posted by abacus07 Quote
thank you - all changed to 'natural' - I will check it out after work ! :-)
08-02-2012, 08:08 AM   #25
eddie1960's Avatar
As far as I know, you only have warranty protection if you buy through an authorized dealer. I'd be a bit surprised if a drug store falls into this group.
London Drugs is definitely an authorized dealer - the name is misleading they sell a ton of electronics - funnily enough when i was in Victoria on the weekend i went in for a battery and film and the K30 prices were higher than Ontario - London drugs is usually very aggressive
08-02-2012, 07:34 PM   #26
tweet25's Avatar
HI, so I tried changing the settings, (set from bright to natural) and I am still getting funky pinks and oranges and reds, all the other colours seem fine. Does anybody have any ideas on what I should try setting the camera at? I don't want to have to process every single photo i get good results with RAW when I adjust them. but the JPEG's are horrible. Please and Thanks - any idea's would be great! Could it be something in the camera that is off?
08-02-2012, 09:04 PM   #27
tweet25's Avatar
hi this is the orange mess ..... Is this normal for a camera to have these colours so way off? am I too fussy? why is it only the red / orange / pinks ???
PS - is shooting in muted a bad thing? that seems to be the best so far ?????? (a little too light, but not bright X 10 )
Ok so I went into the bright setting and then into Parameter Adj. and took the Saturation down to the lowest it would go, and now the pink seems ok... but I guess I will have to see what it does to all the other colouors. Is this kind of thing normal? I didn't have to do this with my K-r.
edit - (well they looked ok in the camera, but once they were loaded they look horrible too)
08-24-2012, 04:03 PM   #28
tweet25's Avatar
QuoteOriginally posted by poseur Quote
i double and triple confirm it will work. using my leftover kr battery adapter on my k30 now after i sold my Kr years ago.
how do you like your K30? and what did you use for a camera between the Kr and K30?
08-28-2012, 12:36 AM   #29
Too me it seems like an color profile problem. If you simply overwrite the camera color profile, instead of converting, it can look really weird. I convert all my photos from adobeRGB (in the camere) to proPhotoRGB in Photoshop. If i simply overwrite, or discard the camera profile, it looks somewhat like your examples. This can be done automatically depending on your settings. I have set it to ask for each picture, so i don't make mistakes.
camera, k30, kr, pentax help, photography
This may be a stupid question but... rockyram Troubleshooting and Beginner Help 18 03-22-2012 04:05 PM
REALLY Stupid Question from *Newbie* BlackSheepBijoux Pentax K-r 10 01-20-2011 03:35 PM
Question ,possibly a stupid one .. arsenal_emyrates Pentax K-r 6 01-10-2011 02:04 PM
A stupid question about K-5 and K-r i83N Pentax K-5 3 10-13-2010 05:42 AM
Stupid question. Looking for stupid answer. dws1117 General Talk 22 11-05-2008 09:51 AM
All times are GMT -7. The time now is 05:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
