08-01-2012, 03:07 PM   #1
subtle or strong correction for tungsten white balance ?
just saw this setting for strong or subtle white balance correction on the k-5, which do most of you use ? ( course i only shoot jpeg )
08-01-2012, 07:33 PM   #2
SpecialK's Avatar
I would use the one that provides the best results most of the time, though a) I rarely shoot in tungsten, and b) I always shoot RAW.
Just test it out and pick what you like. Most settings are subjective anyway.
08-01-2012, 10:51 PM   #3
Well, if the white balance really matters, and you must shoot JPEG, then an Expo Disc would be ideal. In fact, shooting JPEG is a great example of why an ExpoDisc is sometimes more than just a convenience.
08-02-2012, 09:49 AM   #4
Just1MoreDave's Avatar
I would probably have mine on subtle, because I often keep a little bit of the tungsten effect in when I process. The correct white balance sometimes has the wrong mood. I would do some test shots to see what it really does. Light bulbs can have almost any color temperature these days and any auto feature might not do what you expect under all circumstances.
08-02-2012, 06:01 PM   #5
the k-x i had worked best on the strong setting for indoor shots usually, didn't realize the k-5 had the same setting. always have used the default which pretty sure is the subtle setting on the k-5; guess i will try it on strong setting for a bit and see if there is much difference. just wondered what others have used. thanks.
08-02-2012, 06:01 PM   #6
twitch's Avatar
Strong works best for me on both my K-x and K-5
balance, camera, correction, pentax help, photography
white balance kishankx Photographic Technique 5 10-06-2011 09:20 PM
White balance fekish Troubleshooting and Beginner Help 24 10-06-2010 06:31 PM
White Balance on K7 eccs19 Troubleshooting and Beginner Help 6 10-05-2010 09:43 AM
RAW vs Manual White Balance for Color Cast Correction JCharles Pentax DSLR Discussion 18 11-09-2008 07:35 AM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 03:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
