08-03-2012, 04:56 PM   #1
Wired's Avatar
Da* 55mm 1.4 wont af at infinity
Noticing my DA*55mm 1.4 wont lock focus at infinity. I can get it there with quick shift but AF isnt working. Tried calibrating the front and back focus and the problem persists.
I went to exchange the lens but tge shop says its a known problem and they wont exchange or return it because of this. Even though its only three days old. They will send it out to the repair depot.
Ideas?
08-03-2012, 05:02 PM   #2
JinDesu's Avatar
Er what? The shop won't exchange or allow return because it is a known problem? Bullshit - I don't care if it is a known problem, it's still a problem. The shop should take the return or exchange because they get reimbursed through warranty.
08-03-2012, 06:34 PM   #3
remove filter if You use it.
08-04-2012, 03:24 AM   #4
It is not a known problem and they should take it back and get you a decent lens if they want to continue having your business. My 55 has no trouble focusing at infinity.
08-04-2012, 01:52 PM   #5
Wired's Avatar
I went to their main store and they exchanged it. Worked fine in store. But malfuctioning once i got outside... Same issue.
Not running a filter. It WILL focus and lock uaing live view. But not with the OVF.
So went back there. They started blaming my K5. or my custom settings. They only got a K01 and a K30 in stock right now, and it performs fine in the store on those bodies, but on my K5 same issue. Since they don't got any more lenses in stock to exchange they are offering to send it into Pentax for their professional opinion.
I love the lens, I love it a lot. So I think I'll try to adjust backfous/front focus and run some tests with it to see if maybe its user error...
af, da* 55mm, exchange, focus, infinity, pentax help
Using old screw mount asahi lenses wont focus to infinity??? carlyn.warnock Pentax SLR Lens Discussion 19 11-28-2012 10:24 AM
Asahi Super-Takumar 1:1.8/55mm Lens won't focus to infinity bingostew Pentax SLR Lens Discussion 15 10-25-2012 08:19 AM
Pentax DA 50-300mm wont focus to infinity??? TopherTheME Pentax SLR Lens Discussion 5 12-04-2011 07:02 AM
Why don't all lenses have infinity exactly on the infinity stop? peterh337 Pentax SLR Lens Discussion 19 01-15-2011 08:53 PM
SMCP-F 7-210 f4-5.6 wont focus to infinity on Ds? Quenchfire Pentax SLR Lens Discussion 3 10-30-2006 12:18 AM
All times are GMT -7. The time now is 07:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
