08-05-2012, 04:14 PM   #1
set time and date
Hi,
I am very new to the site and have just purchased a K-r. The camera still thinks it is 2010. How do I tell it that we're in 2012 now?
08-05-2012, 06:55 PM   #2
SpecialK's Avatar
By doing what the manual says, normally in the first few pages. It's usually in the camera menu on the left tab.
08-05-2012, 06:56 PM   #3
jatrax's Avatar
Generally such simple tasks are best found in the user manual. In case you do not have one, it is available in pdf form on the Pentax web site. A DSLR is a complicated piece of equipment and you will not get full value from it without spending the time to read the manual.
To answer your question: Press the menu button, I think date/time is under setup menu 1 but I have a k-5 so it is possible it is slightly different. But if you press the menu button and look under the setup menus I am sure you can find it.
Welcome to the forum, by the way.
08-05-2012, 08:35 PM   #4
calsan's Avatar
That's nothing. I still think it's 1998.
08-07-2012, 02:48 AM - 1 Like   #5
sterretje's Avatar
I guess, the first few pages is not quite correct. Page 270 of the manual?
08-07-2012, 11:07 AM   #6
Just1MoreDave's Avatar
QuoteOriginally posted by sterretje Quote
The index would lead you to believe that. They also cover it in Getting Started -> Initial Settings, page 64.
08-08-2012, 03:59 AM   #7
sterretje's Avatar
Yep. To access that, you need a 'virgin' camera And this camera does not seem to be that, else OP would not have asked as he would have encountered it.
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
changed date and time patrick9 Troubleshooting and Beginner Help 7 06-26-2011 05:34 AM
How does my camera always have the right date/time? nixcamic Pentax DSLR Discussion 10 11-07-2010 08:16 AM
Date & Time Issue ladyteri934 Troubleshooting and Beginner Help 8 11-04-2010 04:04 AM
Lossing time and date fanfaron Pentax DSLR Discussion 8 09-30-2010 01:38 AM
All times are GMT -7. The time now is 09:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
