08-07-2012, 02:09 AM   #1
icywarm's Avatar
KX stuck in autofocus, but switch is stuck in MF
My KX will only AF. (unless the lens has quick shift), however, the switch is stuck (will not move with reasonable to slightly more that reasonable force) at MF. Any ideas? I have wanted an excuse for a K5... so do I have a paper weight that will not MF only AF?
08-07-2012, 03:28 AM   #2
calsan's Avatar
Maybe try taking the lens off and then try moving the MF/AF switch? This should eliminate the lens as a culprit.
08-07-2012, 03:33 AM   #3
icywarm's Avatar
QuoteOriginally posted by calsan Quote
Tried that... tried poking at the autofocus thinger(screw), it felt normal.... what gets me is the auto focus seems to be engaged well the switch is clearly set to MF... so i guess there is nothing left but to throw the camera at a wall and ask the Misses if I can have another...
08-07-2012, 06:30 AM   #4
THoog's Avatar
Sounds like the linkage is stuck. I had a similar problem with my K-x due to a fall.
It might be a very simple repair - when researching my problem, I think I read of one person who got it fixed in about ten minutes. I had a cracked faceplate that had to be replaced.
-Todd
08-07-2012, 07:21 AM   #5
icywarm's Avatar
Thanks guys, I guess it is off to pentax for a little TLC...
af, kx, mf, pentax help, switch
K-5 power/depth of preview switch incredibly stiff/stuck, help! JGB Pentax K-5 21 12-02-2017 09:47 PM
Autofocus (Screwdrive) Gets Stuck at a Particular Close Focus Range? paperbag846 Pentax SLR Lens Discussion 5 06-21-2011 09:07 AM
Super-Tak 200mm/4 -- stuck M/A switch RioRico Pentax SLR Lens Discussion 10 05-28-2011 07:36 AM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
Help! Autofocus switch stuck on AF.S and will not autofocus! pauldiebel Pentax DSLR Discussion 3 09-19-2009 08:59 PM
All times are GMT -7. The time now is 04:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
