08-09-2012, 10:53 AM   #1
LeDave's Avatar
Using a CPL on liveview and viewfinder.
I have problems seeing the circular polarizer work through the viewfinder. If I use liveview to adjust the CPL, will there be visible changes in the liveview? I have a Hoya Pro1 Digital 67mm CPL for my DA* 50-135
08-09-2012, 10:57 AM   #2
JinDesu's Avatar
Are you using it outside? With blue sky?
I think I saw a video describing how CPLs work by The Camera Store, and you can see how it affects the sky/reflections in the video. Therefore, it should work in liveview.
08-09-2012, 11:03 AM   #3
LeDave's Avatar
Thanks, will Youtube up some videos now that you mentioned it. I was using to remove reflection from glass.
08-09-2012, 11:49 AM   #4
vladimiroltean's Avatar
Maybe you're using it wrong. It is ineffective both towards the sun and in its opposite direction, and darkens the sky most at 90 degrees left or right to it. I personally prefer to use the viewfinder, because you can see better what's happening through an optical path rather than digital. Also consider unscrewing it from the lens and playing with it a little in front of your eyes, to see exactly what it does. You will notice it has a white stripe which should be pointing towards the sun if you want maximum polarization.
cpl, liveview, pentax help
Idea: Color OLED viewfinder overlay and hybrid viewfinder bwDraco Photographic Industry and Professionals 3 09-28-2012 05:17 PM
Exposure (metering) different in liveview versus viewfinder? pentaman Pentax K-5 & K-5 II 4 01-15-2012 07:55 PM
UV+CPL or CPL+UV stacking and flare? Ryan Trevisol Pentax SLR Lens Discussion 7 05-28-2011 09:11 AM
M42 lens metering differently in liveview vs viewfinder sameagle Troubleshooting and Beginner Help 15 09-07-2010 07:11 AM
All times are GMT -7. The time now is 12:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
