08-13-2012, 10:05 AM   #1
CP filter or step-down ring?
Hi Guys,
I have two lenses with thread diameters of 52mm and 67mm in the front. Now I also have a Tiffen 52mm circular polarizing(cp) filter which is for the 52mm thread lens. The lens with the 67mm thread has been recently acquired and it is going to be the one that will go with me much more than the other lens.
Would you purchase a separate 67mm cp filter? Or can a step-down ring be used for using the existing 52mm cp filter on the 67mm thread lens?
08-13-2012, 10:25 AM   #2
Just1MoreDave's Avatar
You'd probably get a dark circle around the images because your 52mm filter won't cover the full area of the lens's front element. There might be some rare lenses where it would work, 99% of the time it won't.
08-13-2012, 10:27 AM   #3
Well, you could just hold it in front of the lens and see if you get any vignetting.
But I would say it is almost certainly not going to work. There is a reason the front is 67 mm. The manufacturer wouldn't use a front element that large, and add to cost and weight if it weren't needed.
You didn't say what lens it is, but if it's a zoom, it might work at some focal lengths. Kinda defeats the purpose of a zoom lens though.
08-13-2012, 10:51 AM   #4
Thanks Dave and Tanzer. I thought so and you guys have confirmed it.
52mm, camera, cp, cp filter, filter, lens, pentax help, photography, step-down, thread
step down ring or step up ring ? dh4412 Troubleshooting and Beginner Help 5 04-14-2012 04:39 AM
DA 15 Ltd and step up ring(s) and filter(s) jpzk Pentax SLR Lens Discussion 26 03-26-2012 05:24 PM
Purpose-Step-down Ring Sigma 50-500 bezuidar Pentax SLR Lens Discussion 4 07-21-2011 04:09 AM
Single 52-72 step up ring or 52-72 set? geekette Pentax Camera and Field Accessories 11 05-20-2011 09:13 PM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 01:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
