08-13-2012, 03:01 PM   #1
K5 and off camera flash underexposure and high powers.
Hi,
I am wondering if anyone can help me out.
I have bought a Yongnuo YN-560II manual flash for some off camera flash using my K5. I am in manual mode and Slave 1 mode on the flash, using the pop up flash to trigger the off camera flash (shutter speed is not exceeding sync speed). Everything is working as it should be until i go to 1/2 or 1/1 power then the photos become extremely underexposed. This doesn't make any sense to me as the flash should be outputting more power and the camera is at the exact same settings as when using less power on the flash.
Does anyone know what is going on? When mounted on the camera the flash fires at full power and 1/2 power just fine.
Any help would be greatly appreciated.
08-14-2012, 01:39 AM   #2
sterretje's Avatar
Your camera is still using pTTL. Hence a pre-flash from the popup-flash. This pre-flash triggers your remote flash straight away (even before the picture is taken). With full power, there is no power left in the remote flash when the photo is taken and hence the underexposure.
PS:
The yongnuo manual on page 35 suggests to use S2 (pre-flash cancel mode).
08-14-2012, 05:59 AM   #3
Thanks for your reply. How do i stop the camera from using p-ttl? I also tried firing in S2 mode but all images become severely underexposed at all powers. Only in S1 do i get any sort of decent result. The flash is firing when it sees another flash so surely in S2 mode if it thinks the pop up flash is the pre flash it ignores it therefore not firing in sync, creating the underexposed images perhaps?
08-14-2012, 06:31 AM   #4
sterretje's Avatar
Using a manual lens or getting the lens out of A position (if it has one) will result in non-pTTL.
A cheap manual flash to fit in the hotshoe will also do the trick.
I don't have your flash, so can't advise why you're getting incorrect results in S2; the manual might give you some ideas.
You can check pre-flash behavior using the mirror lockup functionality of the camera (and standing in front of a mirror if necessary). At the moment that you press the shutter, you will see the pre-flash in the mirror. Next the mirror goes up and 2 seconds later the picture is taken and you will see the main flash.
camera, flash, help, k5, mode, pentax help, power
BBC: Cameron promises powers to limit executives' pay jolepp General Talk 2 01-08-2012 04:54 PM
High ISO Noise vs. Underexposure Correction yoon395 Photographic Technique 7 08-27-2011 06:13 AM
Optio A36 Fully powers up, then fully powers down. PicturePlant Pentax Compact Cameras 6 08-11-2011 11:45 AM
Underexposure due to flash or body? audiobomber Pentax DSLR Discussion 19 02-13-2009 06:47 PM
All times are GMT -7. The time now is 02:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
