08-13-2012, 03:05 PM   #1
changing the aperture
I have a Pentax istD with Promaster 28 to 80 zoom. Although my zoom has adjustable aperturees, if I put it on anything but automatic, the shutter won't release. Is it possible to shoot pictures with this camera other than with the automatic aperture setting?
08-13-2012, 03:10 PM   #2
DaveHolmes's Avatar
My boy has an istds but he's sleeping and it's in his room... I assume it's a similar process as on my K-x...
You need to go into the menu and set it up to allow use of aperture ring...
08-13-2012, 03:11 PM   #3
I don't have an istD, but with my other Pentax DSLR I must go to the menu and allow the use of the aperture ring. Check in your menu settings and look for 'allow aperture', or something like that.
08-15-2012, 04:02 AM   #4
sterretje's Avatar
Although I don't have the lens, I assume that you can just set the aperture from the camera (in Av or M mode). Am I incorrect in thinking that?
08-15-2012, 07:54 AM   #5
Pentax istD
thanks for the suggestions but so far I haven't figured it out. My menu doesn't seem to have an allow aperture in my menu. I've tried every setting but the shutter just won't release if it's off of automatic
08-15-2012, 08:33 AM   #6
Moo
There is an option, but you shouldn't need to use it as long as your lenses do have an automatic position, as the metering won't be right unless you use automatic. You should use automatic position on the lens, and let the camera set the aperture (or you choose it yourself, using the camera).
08-15-2012, 09:11 AM   #7
boriscleto's Avatar
You have to set the Custom Function to allow shutter release when the aperture is set to something other than A.
Name:  Screen Shot 2012-08-15 at 12.10.20 PM.png
Name:  Screen Shot 2012-08-15 at 12.10.44 PM.png
08-15-2012, 03:25 PM   #8
Not a Number's Avatar
In the "custom menu" there is a setting that needs to be turned on "set F other than A"
08-15-2012, 11:18 PM   #9
Lowell Goudge's Avatar
This is correct, the *istD terminology is not the same as other cameras.
aperture, camera, pentax help, photography
44M aperture/aperture pin issues teartear Pentax SLR Lens Discussion 18 09-19-2011 01:50 PM
Black & White The seasons they are a changing daacon Post Your Photos! 10 09-16-2011 05:21 PM
Landscape Changing weather Aon Post Your Photos! 5 03-27-2011 08:28 AM
New to Changing Lenses maanpayates Pentax SLR Lens Discussion 7 12-18-2010 07:32 PM
Nature Changing Colors clements Photo Critique 4 11-04-2010 02:38 AM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, part of our network of photo forums!
