P-K Tether working very well.
To give an update on my problem, it no longer is a problem. I started using the program for a weekly photo session for my church (taking group and individual photos for membership files and for a church directory) using a couple studio lights (Genesis 200s) with very good results. I have no idea what was happening before, but it apparently has corrected itself.
Yuri, I have taken photos in jpeg, raw and raw+jpeg with excellent results. At this time the only problem I have is remembering to choose the save to folder each time I use the program. If I do not set the file saving parameters at the beginning of the session, the photos do not transfer and the program shuts down.
I do like the auto save setting, too. Not needing to click on the save button after each photo saves a lot of time. I make several new folders in my save file before each session and then simply put the folder number on each family's information card along with the frame numbers of their photos, and after the session I can move the appropriate photos(by frame number) into the proper folder and rename it with the family name. That does take a little time but really makes it easy to retrieve the photos for post processing and for the family to review and decide which ones to purchase.
I think Tomasz Kos deserves a thank you for the program. There are a few minor glitches and/or bugs which, if worked out, would make the program run smoother, but it is a large step in the right direction. I thank you Tomasz.
