08-14-2012, 12:22 AM   #1
mark lj's Avatar
K-5 Problem
Morning folks
Out and about yesterday and went to change lenses on my K-5 when I found that the lens release button has gone missing. How big a job is this to fix? Can I buy a new part or is it something I have to send the camera away for? Couple of big trips coming up within the next couple of weeks including one European trip which is a pure photography trip so it couldn't be at a worse time.
08-14-2012, 12:49 AM - 1 Like   #2
It's a return to Pentax repair, but I've seen a number of posts where others have simply used a probe of some sort to operate the lens release mechanism as a stop-gap pending a convenient time to get a permanent repair.
08-14-2012, 01:11 AM   #3
mark lj's Avatar
That might be the solution - I was worried it might damage the mechanism but I assume if I get something the right diameter and length it will do the trick (although slightly more awkward).
08-14-2012, 04:32 AM   #4
Docrwm's Avatar
Pentax USA has sent out DIY kits for fixing that issue. Call Pentax UK ASAP to see if you can get one mailed to you.
08-14-2012, 06:29 AM   #5
bobhoskin's Avatar
See here:
https://www.pentaxforums.com/forums/pentax-k-5/189715-lens-release-button-replacement.html
I see it's a common problem, better have made one out of aluminum!
08-14-2012, 07:15 AM   #6
mark lj's Avatar
Been on the phone to Johnsons who are the official UK centre. They're stating that it has to go in to them and will be a minimum of 15 working days. They didn't seem to think it was a common fault and hadn't heard of the idea of sending out kits. To say I'm less than impressed with them is an understatement. I've been looking at the possibility of changing to Nikon for ff and have to say I've move3d a lot closer to that plan this afternoon.
08-14-2012, 07:20 AM   #7
Docrwm's Avatar
QuoteOriginally posted by mark lj Quote
I'd contact Pentax UK directly. You can look around the forum and see that several have gotten repair kits, but they have (to the best of my knowledge) been in the US.
couple, k-5, pentax help, trip
Problem with AE-L and K-5 melander Pentax K-5 & K-5 II 8 04-09-2012 03:52 AM
Possible K-5 WR problem fog Pentax K-5 & K-5 II 7 03-15-2012 11:03 AM
A problem unfortunately :( andi Pentax K-5 & K-5 II 4 05-17-2011 10:40 AM
has anyone else had this problem? RubyT Pentax K-5 & K-5 II 2 05-15-2011 03:14 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 06:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
