08-19-2012, 02:17 PM - 1 Like   #16
Not a Number's Avatar
From the manual Green mode reverts to Av mode with non-A lenses or an "A" lens not set on "A". Otherwise the camera uses the "Auto" program-line. I don't know what exposure settings the Auto program-line controls. You probably had the sensitivity set to "Auto" before. Av mode should only expose correctly with non-A lenses when the lens aperture is set wide open.
M42 lenses or a K-mount lens with the diaphragm lever removed may expose correctly in Av mode when stopped down. However, I've noticed as much as 1.5 stops difference vs the exposure selected in stop-down manual metering with a M42 lens (Pentax OEM adapter).
A K-mount lens with the diaphragm lever intact in Av mode would set an exposure as if the lens were always wide open. When you take the picture the lens will stop-down and your image should be underexposed by however many stops you set the aperture from the widest setting.
Removing the lever (I've been told) on most lenses can be done easily and reversibly with a little dis-assembly. Cutting the pin off lowers the resale value (at least to fellow Pentaxians).
helios, lens, mode, pentax help, revuenon
pictures have blue tint in every mode but green mode pearsaab Pentax K-5 & K-5 II 7 01-23-2012 06:13 AM
K-x: Can Aperture be set in Green Mode? Edmund Troubleshooting and Beginner Help 4 06-15-2010 08:21 AM
Sears lens with PK on aperture ring (K mount??) jqjones Pentax SLR Lens Discussion 3 02-16-2010 10:20 PM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
using an aperture ring lens on the K100D Super burntsienna Pentax DSLR Discussion 3 02-25-2009 02:10 PM
All times are GMT -7. The time now is 04:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
