08-21-2012, 11:29 PM   #1
K20D water damage
Dunked my K20D in a mountain stream for just a couple seconds, and after all the usual methods meant to dry it out - blow dryer, rice, took it in for repair. The shop said there was a bit of corrosion in one area, so they sent it to Pentax repair in Arizona. Has anyone had any luck with this same situation? The good - the camera still read the SD card and everything to the left of the LCD screen still worked. The bad - the shutter and the dials next to it would not work. Now it is at the mercy of the pros.
08-22-2012, 12:43 AM   #2
usn ret's Avatar
Now, this is sad but, it could have been a new K5. Keep us posted on the repair....Cliff
08-22-2012, 07:25 AM   #3
Banned
I've found that most memory cards can be retrieved (some even completely) even when the memory card is fully immersed in most any water; hot tub, even salt water.
But as for the camera... Did you happen to notice which area(s) of the camera the water hit? You stated it was dunked, but how so please?
Did it effect only towards the based plate; towards the front; or did the entire camera go under?
08-22-2012, 09:44 AM   #4
Entire camera went under. I was standing in shallow water, but slipped. It was only wet for a couple seconds, and water was fairly clean, but still did some damage.
08-23-2012, 08:54 PM   #5
mysticcowboy's Avatar
I've had the circuit board around the shutter button and controls replaced. It wasn't water damage, but the camera came back from the repair and works great.
10-01-2012, 10:47 AM   #6
usn ret's Avatar
Bump, what is happening with the K20D? Good news I hope. Cliff
10-01-2012, 02:22 PM   #7
Ex Finn.'s Avatar
QuoteOriginally posted by usn ret Quote
If it went to C.R.I.S. they most likely have just now had a chance to check it out.
k20d, pentax help, repair
Will I damage my takumar with UV? dmbaile2 Pentax SLR Lens Discussion 6 08-03-2012 04:31 AM
Pentax K-7, FA 77 Water Damage (ugh): Suggestions? messthetics Pentax DSLR Discussion 12 11-12-2011 02:00 PM
k-7 battle damage akuli Troubleshooting and Beginner Help 7 02-06-2011 09:19 AM
For Sale - Sold: K20 water damage sale (Worldwide) FHPhotographer Sold Items 10 11-17-2010 08:13 PM
K20D Rain Damage paulelescoces Pentax DSLR Discussion 64 11-07-2010 03:19 AM
All times are GMT -7. The time now is 04:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
