I'm with Doc lets get it back to simple since you are a novice. your lens is not letting in enough light, which could be fixed somewhat by bumping the iso up to a higher number but that will be at the expense of noise in the shot, possibly more than is acceptable to you. Ideally you need a faster (ie as doc said smaller number F stop) lens.
If you only need a little more reach to get the shot you want the tamron 18-75 2.8 would be an excellent and affordable choice. if you feel you need to get in even closer (more reach) then maybe get the Tamron 70-200 2.8. the main issue here though may well be at 70 it will frequently be to long. in any case the 28-75 is probably a better starter good zoom, you can always crop a little for the framing later and at 28 it will be wide enough for many situations, you can always add the 70-200 later
As for the camera thing, like doc said wait. lenses are a good investment, you keep them for a long time if they are good. Camera bodies all have one thing in common they are always replaced by a terr model and they always go down in price for the features. better to build your skills first and your basic lens kit (say within tamron the 10-24,28-70 and 70 200 - all good lenses all affordable) then move up on the body to one that meets your budget and needs.
