Originally posted by DaveHolmes 'm looking for deals on K-m's, K-x's and K20's but would older Pentax dslr's be an improvement on the HS10 - Say K10, K200d, K110, IST(d,ds) etc?
Our boy uses an IST-DL (or S... can't remember) but I haven't seen much off it to be honest (he uses it lees than I'd hoped) should I get her to use that (with better lenses than he has) for a while and see? (hoping he won't mind)
Dave go look for a k10d or k110d both will give good results up to iso800 without being noisy and you can remove what there is with little softening as it is a small correction, they are cheap enough now here in the uk.
the last post with advice on lenses is good advice do that, you have more glass than you could ever need,
