Hi all,
This may or may not be an issue with my K-x, so bear with me.
I recently purchased a little iPhone app called "
DSLR.Bot", some of you may have heard of it - it's pretty nifty. I bought it to allow Bulb (> 30s) exposures for astrophotography. You need an IR cable for it to work, I made my own as per the DSLR.Bot link to the
guide on the Instructables website. The first exposure always works, as follows:
1. Start app, set exposure to 35s, delay to 5-7 seconds (more than enough for image processing/saving etc), repeat to 9999.
2. Press start - shutter opens as expected.
3. 35 seconds later...
4. Shutter closes as expected.
5. Delay timer kicks in
6. 5-7 seconds later...
7. Exposure timer starts again (as if to assume that another "open shutter" signal has been fired off) but...nothing...? The red light is flashing near the IR receiver to let me know that the camera IS ready for another IR input.
Any ideas? Thought this may be a setting in the K-x or something. The creator of the app seems to have gone AWOL, as it's a slightly dated app.
EDIT: Strangely enough, using Mode 1 (toggle shutter in Bulb) or Mode 2 (hold shutter in Bulb) has the same effect - First exposure is fine, second never works.
