08-25-2012, 09:12 PM   #1
tweet25's Avatar
Problem?
Hi - I am wondering if anybody would know what causes this? the camera was a Kr with about 20,000 photos, and out of 40 taken that day, 4 turned out like this?
and the preview screen went weird white on some of the other shots, but those ones were fine. These photos were taken inside with an external flash (pointed up)
thank you
PENTAX K-r  Photo
08-25-2012, 09:53 PM   #2
Would seem to me that the flash didn't fire, according to the EXIF: Flash Used No
I'm guessing you didn't give the flash enough time to charge and the option to not allow the shutter to release if the flash is not charged has been disabled.
As for the weird white areas on the preview screen, I believe it was showing you the overexposed areas of the shot.
08-25-2012, 10:19 PM   #3
tweet25's Avatar
thanks elliott - my daughter-in-law was using my camera - and when i downloaded the photos i was freaked out. I thought my camera was broken. I have never had that happen before.
I will have to park my K30 and shoot with my Kr tomorrow. thanks again
08-25-2012, 10:43 PM   #4
I believe the setting is called "Release While Charging", it is in the custom settings menu. That will prevent this from happening again, just don't panic when the shutter doesn't trigger.
08-27-2012, 09:07 PM   #5
mysticcowboy's Avatar
Your problem is that you enabled "ghost mode". I think it's in the paranormal setting menu. Turn it off with ESP.
camera, pentax help, photography, photos
K5 sent back for 'mirror slop' problem but came back with much worse problem captainbert Troubleshooting and Beginner Help 24 07-10-2012 01:08 PM
Possible K-5 WR problem fog Pentax K-5 7 03-15-2012 11:03 AM
Is this a front focusing camera problem or lens problem? Lens tests Metalwizards Pentax K-r 15 03-06-2011 01:24 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
All times are GMT -7. The time now is 07:06 AM. | See also: NikonForums.com, part of our network of photo forums!
