08-28-2012, 01:39 AM   #1
Newbie here
Hey guys!!!
Just got a Pentax ME Super from my uncle and this is my first camera.
Just wondering what is the best lens (wide angle) for a newbie to learn up about photography?
Thanks and sorry for such a newbie question.
08-28-2012, 02:05 AM   #2
How wide and what is your budget? What do you have now?
08-28-2012, 02:11 AM   #3
Currently, i'm having just the SMC Pentax M 50mm f2.8 and just sent my camera for servicing.
Is it advisable to get M 40mm lens for wide angle purposes? and also less than $60?
08-28-2012, 02:17 AM   #4
kiwi_jono's Avatar
Welcome. I have a ME Super (as well as a K-x DSLR) - its a nice camera - nice bright view finder!
I have a Pentax M 28 f3.5 which I love (and is surprisingly cost effective) but there are lots of other options as well. Pentax K and M series lenses work well, as do Takumars (with M42 adaptor) - not to mention many other brands with K mount.
For wide angle I am guessing you are probably looking for lenses with a focal length of 24 - 35mm (unless you want to go really wide).
For M series lens reviews see: https://www.pentaxforums.com/lensreviews/category-SMC-Pentax-M-Lenses.html
Enjoy!
Jonathan
08-28-2012, 04:36 AM   #5
In my opinion the 50mm is a great focal length to learn with. If you want something wider than I would start to look for something around the 28mm mark. I never owned an ME Super but from what I remember it was a great camera. Have fun.
08-28-2012, 04:39 AM   #6
@ Jonathan: Thanks for the info!! I know there is a difference between Pentax M mount with Pentax A mount, but not really sure with K mount. Enlighten me?
08-28-2012, 05:05 AM   #7
kcobain1992's Avatar
QuoteOriginally posted by daystriker Quote
There isn't really M or A mount, it's just the basic K mount, which has some extra pins in the case of A-series lenses (the reason they usually sell for more too). Nothing to worry about for you, because those pins won't make any difference anyway on the ME. I'm not sure what lens is that 50mm f/2.8 really, I think Pentax has no such lens. Anyway, the 40mm isn't considerably wider than the 50mm, I would suggest you get the M28/2.8, as it's plentiful and very nice.
08-28-2012, 05:07 AM   #8
ChooseAName's Avatar
If it's Pentax and it's not screwmount, it's all K-mount (I think). The M and A are lens designations, with M meaning everything is manual, and with A meaning that you can set aperture using a camera dial instead of the lens' aperture ring.
08-28-2012, 05:19 AM   #9
Docrwm's Avatar
THe ME Super is a K mount camera so any of the K, M, or A lenses will work on it. The M28/2.8 is a very affordable, easy to find, and descent wide lens to start with IMHO.
08-28-2012, 08:52 AM   #10
Just1MoreDave's Avatar
For your camera, the lens series look like this:
M - designed around the same time, functionally 100% compatible.
K - designed for a larger camera series, 100% compatible, don't actually say K on them, sometimes hairsplitting differences between M and K
A - more expensive than M lenses because of features you don't need
F,FA, FA-J, D-FA - way more expensive than M lenses because of features you don't need, plus a terrible focus ring
DA, DA-L - won't work in a useful way
The classic wide angle for your camera is a 28mm. These will be common and cheap as f2.8 versions, such as the M28/2.8. Vivitar made some f2.0 versions that are still affordable. These should be cheaper than 24mm or 35mm lenses simply because of supply.
The Pentax-M 40mm f2.8 is extremely compact on your camera but not too wide-angle. Unless the size is important to you, I'd look for other options first.
08-28-2012, 03:26 PM   #11
screwdriver222's Avatar
I used to have a Pentax MEF, basically a ME Super with a focusing aid. The only lenses I had were a M50mm f1.7, Takumar 28mm f2.8 and a Tamron AD2 80-210 (103). Thats all I used for about ten years. I think the Tak was a version of the M28mm f2.8. I would recomend getting a 28mm for the wide angle and the Tamron which can be picked up cheaply on ebay.
Jeff
camera, newbie, pentax help, photography
Newbie with K-x alowis Welcomes and Introductions 3 12-30-2010 07:03 PM
Help for a newbie... MidwestKX Troubleshooting and Beginner Help 12 11-24-2010 07:03 AM
Hello from a newbie johnnyjet Welcomes and Introductions 2 11-01-2010 03:41 PM
Newbie from th UK scottbt Welcomes and Introductions 2 10-22-2010 04:29 PM
newbie newtopentax Welcomes and Introductions 4 09-27-2010 07:04 AM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
