Originally posted by Spodeworld So, to be sure, are you saying that the Green button doesn't work (e.g. in Manual mode set shutter speed) with an F but will with an FA?
No, that will still work. I was referring to Green Mode, i.e. turn the exposure mode dial to the green rectangle. That said, it's possible (I'm only guessing) that you would get different values (in some cases) using M mode plus Green Button with an F- versus FA-series lens. MTF program line is the lens telling the camera what aperture values give the highest resolution. If the camera has that info it will use those aperture values when feasible. Lacking that info I suppose (guessing again) that the camera has default shutter and aperture values for a given meter reading.
