08-28-2012, 08:09 AM   #1
Spodeworld's Avatar
F vs. FA lenses
It seems that F and FA lenses have pretty much the same capabilities:
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
so I was wondering what the difference is.
For example, if I am comparing a F 50mm f1.7 and a FA 50mm f1.7, what would I expect the differences to be?
Thanks.
08-28-2012, 08:18 AM   #2
baro-nite's Avatar
For most uses, the main difference between the F and FA series is mentioned in the article you link:
While FA lenses are identical in operation to F lenses, they feature improved electronics that support the MTF program line.
Of the specific lenses you mention, optically they are essentially the same. So the only functional difference will be if you use a shooting mode that uses MTF, namely Green or P mode.
08-28-2012, 08:18 AM   #3
boriscleto's Avatar
The differences between F and FA lenses is mainly build quality. Optically the F50 and the FA50 are identical.
Edit: And what baro-nite said about MTF. For some reason I thought it only applied to FA J and the FA Limiteds.
08-28-2012, 08:25 AM   #4
Docrwm's Avatar
Got it covered in two posts - MTF and build quality. All other things being equal (cost, shape of the lenses, etc.) the FAs would be a first choice.
08-28-2012, 08:32 AM   #5
audiobomber's Avatar
What build quality difference is there between F and FA? They look and feel pretty similar to me; good quality plastic shells and metal mounts. Is one supposed to be better built?
08-28-2012, 08:38 AM   #6
boriscleto's Avatar
QuoteOriginally posted by audiobomber Quote
I believe the F lenses have metal barrels while the FA lenses have plastic barrels. That would account for the weight difference between the two lenses (205g vs 170g).
08-28-2012, 08:45 AM   #7
Isn't the fa version of the 100-300 said to be optically better than the f version?
08-28-2012, 08:46 AM   #8
mysticcowboy's Avatar
My F 50/1.7 has a plastic barrel. Also, since some FA models are still being manufactured, the newer models have better anti-flare coatings than the older F models.
08-28-2012, 08:59 AM   #9
jatrax's Avatar
The F series is simply much cooler. FA series is fine but boring.
08-28-2012, 09:04 AM   #10
Just1MoreDave's Avatar
QuoteOriginally posted by mysticcowboy Quote
The F50/1.7 is weird - plastic shell that feels cheap over mostly metal interior. The A50/1.7 feels better built, yet with more interior plastic.
08-28-2012, 09:16 AM   #11
seventysixersfan's Avatar
I haven't done scientific testing on this but I subjectively feel like my F series lenses (F 28mm, F 35-70) auto-focus a bit faster than my FA lenses (FA 35, FA 50). Not that the FA lenses are slow by any means but the F series just "snap!" into focus with a quick motion.
08-28-2012, 09:26 AM   #12
boriscleto's Avatar
QuoteOriginally posted by Boker Quote
There are two different versions of the FA100-300. The first has power zoom and is F4.5-5.6, it is said to be worse than the F version. The second is F4.7-5.8 and is said to be the best of the 100-300s, the Silver version anyway. The Black version is said to have problems with DSLRs.
08-28-2012, 09:29 AM   #13
boriscleto's Avatar
Internal or external? All the F series lenses have plastic exteriors, it's the interior that is supposed to be metal.
08-28-2012, 09:31 AM   #14
QuoteOriginally posted by seventysixersfan Quote
My newly acquired F35-70 literally "snaps" into focus, and so does my F50 f1.7. Both autofocus faster than SDM lenses. My FA Limiteds are slightly slower, and the build quality is second to none(except Zeiss PK).
08-28-2012, 09:47 AM   #15
QuoteOriginally posted by boriscleto Quote
I had an F 28mm, the build seemed no different than my FA lenses, and it is 5g lighter than the FA 28mm according the specs in the Lens Reviews on this site (185g vs 180g).
50mm, camera, f1.7, fa, lenses, pentax, pentax help, photography
Do m42 lenses measure up to todays lenses? Vantage-Point Pentax SLR Lens Discussion 25 05-14-2011 07:51 AM
Huge test on the influence of fungus in lenses (on 9 lenses) CarbonR Photographic Technique 18 03-14-2011 10:34 PM
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
For Sale - Sold: Yard sale: M lenses, K 300mm, DA 14mm, ME film body, Nikkor lenses and more Nachodog Sold Items 24 12-26-2009 12:03 AM
All times are GMT -7. The time now is 02:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
