08-29-2012, 02:21 PM   #1
HOYA HMC 75-205mm K mount does't fit my K100D super
Hi,
I was looking for an affordable zoom lens for my K100D super. I bought a HOYA 75-205mm Zoom and Macro (420365) lens with a K mount.
I did a fair amount of research and believed it was compatible, having to focus manually. However I do not seem to be able to fit the lens at all. It looks like a K mount with a red dot and the correct bayonet shapes and sizes. If I line up the red dot on the camera body and the lens it does not interface. I can align the lens with the correct spaces in the body (i.e. red dots not aligning), so the two interface but then I can not twist and lock the lens in place.
There was a small pin on the mount that I removed, but still had no luck. It looks like the flange depth is too narrow to fit the K100D body.
Has anyone come across this incompatibility of a HOYA K mount before? Or am I just missing something really simple?
Any thoughts would be appreciated.
Thanks
08-29-2012, 02:31 PM   #2
jatrax's Avatar
Pictures would help. Not sure about the Hoya but a number of older Vivitar lenses had a large flange to protect the aperture lever. The flange hits the SDM contact plate on modern cameras. If this is the problem the flange can often be removed with a few screws and either left off or ground down on the Dremel to make it fit.
Post a picture and I can tell you better, I'm just guessing without seeing it.
08-29-2012, 02:36 PM   #3
ChipB's Avatar
If it really is a Pentax K-Mount, then it might have a long flange that 'protects' the aperture actuating pin. If it does have a flange, it shouldn't be more than about 1/2" in length.
Simple to fix with a dremel tool - first remove the black piece that attaches to the rear of the lens, then simply cut down the flange. Or, just leave the piece off the lens - it really doesn't *do* anything. If you do a forum search you'll come up with several postings that include pics.
If this isn't the problem, then it would be very helpful if you could post a photo of the lens mount.
body, camera, dot, hoya, interface, k100d, lens, mount, pentax help, photography, super
Hoya HMC Tele-Auto 135mm 1:2.8 lens, Pentax K Mount + Case DaveHolmes Pentax SLR Lens Discussion 2 06-19-2011 10:31 PM
For Sale - Sold: Hoya HMC Super UV(0) Filter (77mm) (Worldwide) DaveInPA Sold Items 2 11-06-2010 06:26 AM
For Sale - Sold: Hoya HMC Super UV(0) Filter - NEW Stratario Sold Items 3 05-30-2009 03:54 PM
For Sale - Sold: 67mm Hoya HMC Super UV(0) Filter - New Stratario Sold Items 2 05-30-2009 01:59 PM
HOYA HMC Super vs DMC vs HMC wlachan Pentax Camera and Field Accessories 6 08-23-2008 05:43 AM
All times are GMT -7. The time now is 03:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
