09-24-2012, 01:15 AM   #31
kh1234567890's Avatar
QuoteOriginally posted by newarts Quote
When displayed at 100%, each point of light in the original scene is spread over 5 pixels on the display (almost 1mm). No wonder it looks fuzzy!
Without wanting to get into an argument, I suggest that you are talking boll*cks, as we would say around here.
09-24-2012, 09:22 AM   #32
QuoteOriginally posted by kh1234567890 Quote
How so? The theory is well established & my application of it was conservative.
The K-5's high pixel count means that a 100% crop maps a very small sensor area to each display pixel.
Here's an illustration from Luminous Landscape of a Gaussian distribution (very similar to the Airy distribution expected from a lens) on a square grid of pixels. The Gaussian "spot" is about six pixels wide, just like op's case.
From LuminousLandscape - Deconvolution sharpening revisited
Clearly, what idealy be a single bright pixel is smeared out over quite a few of its neighbors.
The following is an attempt to give a reasonably useful approximation to what's going on in theory.. It ignores AA filters, etc..
Following Airy disk - Wikipedia, the free encyclopedia the Gaussian approximation to the Airy Disk is:
Relative brightness = exp(-(x^2+y^2)/(N/2)^2)/[(N/2)^2(Pi)] where x, y are in microns and N is the f-stop number.
The center brightness of a multi-pixel spot varies with 1/N^2, so an F:11 spot's center is about 4 times brighter than an F:22 spot's center.
Dave
PS I note your signature "Knowledge does not equal understanding." - true, but Ignorance is certainly a worse predictor of understanding.
Sharpness, Fine Sharpness, Extra Sharpness Taviali Pentax K-5 8 03-31-2012 12:56 PM
Nature need help - sharpness citrus sky Photo Critique 16 02-02-2011 05:51 PM
Sharpness VS Fine-Sharpness in k20d wasim_altaf Pentax DSLR Discussion 8 10-12-2009 11:41 AM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
All times are GMT -7. The time now is 07:55 PM. | See also: NikonForums.com, part of our network of photo forums!
