09-04-2012, 03:48 AM   #1
Green laser
Hello Folks,
I've noticed that my K-5 has what appears to be a visible-light green laser range finder. When I'm using the 50-200 WR lens it only comes on when the lens is set long, at or about 200 mm. Why?
Thanks, Tom
09-04-2012, 04:10 AM   #2
Docrwm's Avatar
Its a focus light to aid the autofocus.
09-04-2012, 04:11 AM   #3
boriscleto's Avatar
That is the AF Assist Light. In AF.S mode it will come on when the camera determines it is needed.
09-04-2012, 04:11 AM   #4
victordeamorin's Avatar
Hi Tom,
I assume you're talking about the small green light in the upper right part of the camera. This is an AF assist lamp. AFAIK it is not a laser device bt just a simple green LED. It is deisgned to help the camera autoocusing in dark conditions. Obviously it is only efficient at close range.
I'm guessing in your case it only turned itself on at longer focal length, because that is the most demanding situation:
- because of camera shake if you're shooting handheld;
- because on that lens the max aperture is limited to 5.6 instead of 4 at shorter lengths.
You can also choose to deliberately turn the green light off somewhere in the "C" menus. Look for "AF assist".
EDIT oops, I was too slow!
camera, laser, lens, pentax help, photography
CMOS Laser Damage SuperK5 Pentax DSLR Discussion 10 11-17-2012 07:04 AM
k20d - laser assist Hey Elwood Pentax DSLR Discussion 5 05-23-2012 10:07 PM
green laser... no, not a new superhero dcmsox2004 Pentax Camera and Field Accessories 25 01-20-2012 02:47 PM
"Rose" made with a green laser allesschonweg Monthly Photo Contests 0 11-06-2011 12:51 PM
Caution: your camera maybe ruined by a laser Nass Pentax DSLR Discussion 10 10-18-2011 03:01 PM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
