09-04-2012, 01:30 PM   #1
Spodeworld's Avatar
Trying to figure out which part
Hi.
I am acquiring a Pentax F 1.7 50mm lens that is missing the ring which you turn for focus. I have attached pictures here.
I contacted Pentax Parts, and they sent me a part list sheet, but I'll be damned if I can figure out which part it is. The person I spoke to cannot do more than help me order something. I've attached the parts sheet for the lens (at the bottom).
Based on the lens pictures and the parts sheet, can anyone help me figure out which part I need to order?
Thanks
PENTAX K10D  Photo
PENTAX K10D  Photo
09-04-2012, 01:52 PM   #2
It's the 0-F131 you can see the 4 notches around it but you only need the outer ring part, looks like a big job to change the whole piece. Maybe it can be removed and re glued to your lens that would save you a complete dismantle.
The lens will still work without it in auto focus.
Good luck
09-04-2012, 02:12 PM   #3
Spodeworld's Avatar
@bob...thanks, I thought that that might be a candidate, but I was expecting a simple ring...but you're probably right. I was under the impression from the lens pic that it would be something that you would just pop on, kind of like a ring, but from the sound of what you are saying....it ain't so straight forward.
Anyway, according to the seller, not only does the AF work, but you can still MF without any problem using what is there....having the ring on it would look nice though.
09-04-2012, 03:39 PM   #4
you could use a black "tie wrap" and cut off the excess tail. You then have something with grip plus you can quick focus by using just the locking clip of the tie wrap a la Leica's focus ring tab...just an idea fwiw
http://www.homedepot.com/catalog/productImages/300/ed/ed2a918b-7de1-4d2e-bed...54eac1_300.jpg
09-04-2012, 05:28 PM   #5
Spodeworld's Avatar
That's an idea...thanks. I was thinking of going to Home Depot and seeing if they had anything that would work.
QuoteOriginally posted by Franky2step Quote
09-07-2012, 06:12 AM   #6
Hi
Maybe one of these will do.
Greetings
Lens Band STOP ZOOM CREEP for Pentax 28-70mm in Black | eBay
09-07-2012, 08:54 AM   #7
Spodeworld's Avatar
@Schraubstock - That looks like a good idea....seems like it for a larger lens though (67mm up)....but thanks for the idea....
09-07-2012, 11:01 AM   #8
Lowell Goudge's Avatar
are you sure of the part, it actually looks like the lens is missing the D101 read the descriptions the 0-F-131 is already on the lens, it is the distance scale shich projects into the outer barrel, under a window,
09-07-2012, 11:03 AM   #9
Just1MoreDave's Avatar
I would view this as an opportunity to improve on the original ring which is pretty thin to MF with. A tie wrap will almost look original, with its teeth resembling the grips on the real part.
09-07-2012, 12:37 PM   #10
Spodeworld's Avatar
@Just1More.......maybe I'll give that a shot....easy enough to try....the hardest part is getting the time to go out to Home Depot
09-07-2012, 06:56 PM   #11
QuoteOriginally posted by Spodeworld Quote
They come in a whole range of different sizes !
figure, lens, pentax, pentax help, pictures, sheet
Can't figure this out! polur101 Flashes, Lighting, and Studio 8 05-04-2012 09:54 PM
Can't figure this out...? rollin Pentax K-5 6 04-25-2012 12:08 PM
Not Work-Safe Figure Study enoeske Photo Critique 5 03-31-2011 03:21 PM
Can't Figure Out Bellows Dubesor Pentax SLR Lens Discussion 12 03-14-2011 11:27 AM
People Figure/Silhouette candgpics Photo Critique 5 11-21-2010 08:26 AM
All times are GMT -7. The time now is 05:19 AM. | See also: NikonForums.com, part of our network of photo forums!
