Originally posted by kokezuniga Mmmmm, very tempting, but, if I remove the top of the camera, do I lose the weather sealing?
Perhaps. It depends on how careful you are when you reassemble the camera. I got some Silicone spray lube and sprayed some of the lube into the plastic cap that came with the Silicone can (spray away from your open camera to keep overspray mist away from all the camera internals). I then used a toothpick and dipped it into the cap and applied a small amount of the liquid to the the seal areas before reassembly. That allowed the top cover to slide down easily. I believe that the seals are still intact, but I don't push it. I don't clean a camera with a garden hose. The camera has been in a light rain and also in the snow since the repair, no problems.
