09-08-2012, 01:19 AM   #1
K-R Locks up in bulb mode on longer shots
Hey everyone, wondering if anyone else has come across this issue; when using the K-R on bulb mode and doing a longer exposure (say 60sec +) the camera will lock up and be completely unresponsive. No display, no reaction to buttons or shutter, even flicking the power switch off and back on does not bring it back. I have to pull the battery to get it going again. I first discovered the issue when firing the shutter with the IR remote but just tested by holding the shutter and replicated the problem. I'm on FW ver. 1.12 so the camera is up to date. Thoughts?
09-08-2012, 04:11 AM   #2
Anvh's Avatar
Thats most likely the dark frame substraction, its a form of noise reduction. It works by taking exact same photo again so with the same exposure time. I believe you can turn it off with the Kr
09-08-2012, 06:39 AM   #3
mattt's Avatar
Yup, slow shutter noise reduction. The bottom of camera settings tab 2. I left mine on auto, but was quite concerned when I experienced the same as the OP - after learning about DFS its not a concern, I let the camera finish its processing.
09-08-2012, 10:59 AM   #4
Oh hahah, intentional feature! Just did an experiment by doing a 60sec exposure and letting it sit for another 60sec, sure enough it was ready to work again after that.
Thanks for your help, much appreciated!
bulb, bulb mode, camera, issue, k-r, mode, pentax help, shutter
Bulb mode Matheias Pentax K-r 7 11-09-2013 07:54 AM
Bulb mode MrK5 Pentax K-5 & K-5 II 11 01-25-2012 05:52 AM
Issue with Bulb mode Swapnil Pentax K-r 7 06-09-2011 09:02 AM
Has anyone tried the Bulb Mode on K-5 Pentax Lover Pentax DSLR Discussion 22 11-24-2010 07:27 PM
Problem with K-x in Bulb mode Dimitris M. Pentax DSLR Discussion 6 11-14-2010 10:36 PM
All times are GMT -7. The time now is 02:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
