Originally posted by moshepupkin Hi there, I'm having a problem with autofocus on my k-x camera with Tamron 17-50mm F2.8 lenses. Basically the problem is - in about 50% of the times I'm trying to take a picture the autofocus does not work, I mean it simply refuses to focus. Usually moving a camera a little bit helps, but sometimes no matter what I do it simply would not autofocus! What's wrong?
Originally posted by moshepupkin I've also noticed that sometimes the camera would switch from AF to MF and vice versa even though it is set to AF! How can it be!?
When did you buy your camera? Mine was circa 2010, and I'm encountering similar problems. I figured out a solution though I am not sure if it is the same for your problem. There are a few things you need to make sure first:
1. The problem is that the focus gets stuck at
either MF or AF, regardless of, for example, the switch was set to AF and the display says "MF" or when the switch is at "MF" but the display (and active focus mechanism) is still AF.
2. Clean all contacts on the camera mount. DO NOT use any liquid cleaning agent, a clean microfiber cloth will do.
3. That the problem exists on
all lenses you mount on your K-x.
...Check the screwdrive screw with the lens off- it should be perfectly centered in the hole it comes in and out of. A little difference won't matter, but if it, say, skids along the edges when it pops out of the body (in AF mode), have a Pentax technician check it.
4. Check the switch - remove the lens first. When you switch the focus switch to AF, the screwdrive screw should pop out of the body. In MF, it should sink into the body. Also, while in AF mode, the screw should be able to sink into the body given some pressure - this ensures that the spring underneath it is not damaged.
5. If all things are how they should be as in #4, carefully move the switch between the modes. You should feel something like a slight semi-click before it moves fully down or up. This means that somehow, one of the contacts that confirm that the camera has switched AF modes has loosened up or is not aligning properly. This solution will work but you have to be very careful in switching from now on, if you want to avoid spending on body repair.
IF the AF works properly on other lenses, then it's one or other particular lenses your K-x is having problems communicating with. If #5 does not solve the problem, have an authorized (or otherwise very knowledgeable) camera technician check it.
The screwdrive AF problem also
should not affect your camera's ability to use the AF of KAF3/SDM lenses
