Originally posted by Spodeworld If the focus points are too large for accuracy, is there an approach to take to help mitigate the problem to improve accuracy?
Hi Spodeworld,
I suggest taking some time to experiment to map the actual area and location of the focus points that you use in relation to the etchings on your focusing screen first. Make sure that the diopter is adjusted correctly for your vision, then when you shoot, concentrate on the subject in the viewfinder with the same intensity that you would if you were focusing manually, confirm focus visually, then take the shot. I also try to be very aware of everything else in the focus sensor area and try make something on my subject the dominant contrast border in the focus sensor area. Once I'm satisfied that my subject is in focus, I lock focus, recompose as necessary, and take the shot.
The central focus sensor area is the largest and probably the most sensitive. It's roughly the size and location of the central ( ) markings on your viewfinder, but location can vary slightly from camera to camera. The actual sensor is cross shaped with lines bisecting the circle vertically and horizontally like the traditional picture of the crosshairs in a rifle scope. It senses contrast borders that intersect the lines of the sensor. The AF system tries to find the point where contrast borders intersect the sensor lines and make them as narrow as possible (maximizing contrast on the sensor). The system cannot guess your intended focus point, the photographer must make sure that you give it something to work with.
Scott
