09-15-2012, 10:51 AM   #1
ChooseAName's Avatar
Metz 48 refuses to fire at dialed power with K-x
I have a Metz 48 flash, K200D, K-x, and mostly manual lenses. When I have the Metz on the K200D with a manual lens, the flash will fire at the power which I've dialed in. When I put it on the K-x (moving the lens from the K200D as well), the flash fires at what looks like the weakest power. Is there some setting on the K-x which is preventing me from setting flash power?
Another data point is that when I have a modern lens (DA35/2.4) on the K-x with flash, the flash will fire at intended power.
I have cleaned the hot shoe contacts on the K-x and that didn't do anything. Both bodies were in M mode the whole time.
This does not seem like normal behavior to me. Is it normal for K-x's? Or did I just get a bad copy? I've also posted recently about what I think/thought might be viewfinder/focus issues: https://www.pentaxforums.com/forums/general-technical-troubleshooting/198991-...sus-k200d.html
EDIT: I did not change any flash settings, the flash is on P, TTL, HSS mode. I don't think it's an issue of flash battery charge level, since the flash indicates that it's ready to fire. Also, I uploaded two images from the K-x, with EXIF intact: one with manual lens (M 85/2) and flash fired; and one with modern lens (DA 35/2.4) and flash fired.
PENTAX K-x  Photo
PENTAX K-x  Photo
09-16-2012, 03:50 AM   #2
I don't know if this is your problem. I have a third party pTTL flash that works fine with my K200D, but doesn't work with my K-R. Seems Pentax changed the electronic settings in the newer cameras. You could contact Metz and see if there is a firmware update for your flash.
09-16-2012, 05:17 AM   #3
QuoteOriginally posted by gp1806 Quote
Thanks! The firmware update fixed the problem. I didn't need to contact Metz because they have all their firmware updates on their website.
fire, flash, k-x, k200d, lens, metz, mode, pentax help, power
How to power 540FGZ flash with Alienbees Vagabond mini II portable power? shadowbecomeswhite Flashes, Lighting, and Studio 2 07-25-2011 07:17 PM
K-x refuses to capture seww Pentax DSLR Discussion 4 12-26-2010 07:37 AM
Cactus v4 triggers, Pentax K20D and Metz 58 won't fire. luke_sheff Flashes, Lighting, and Studio 5 03-16-2010 12:05 AM
WTF? K100D now refuses to recognize non-DA lenses. mulanrouge Troubleshooting and Beginner Help 11 09-28-2009 01:03 PM
Big Iron - Fire Power of Another Era Sailor Post Your Photos! 23 06-20-2009 10:43 PM
All times are GMT -7. The time now is 05:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
