09-16-2012, 11:43 PM   #1
K10D aperture control error
Hi!
I've got a problem with my camera. When I setting up aperture on the body, and then press the shutter, the camera don't set up the correct apperture, but shot in wide open. I tried 2 of my af-lens, and both generates same problem. I've got a 50mm f1.7, that works like a dream in manual mode.
When I use my 18-55 kit lens, it works just f3,5-5,6 only. Contacts are cleared both the lenses, and the body too.
Any idas? I have to give my body to service?
09-17-2012, 12:34 AM   #2
Does the lens stop down when you use the optical DOF preview?
09-17-2012, 12:55 AM   #3
No. I tried both two af-lenses. But on my manual lens the optical DOF preview is working.
09-17-2012, 12:58 AM   #4
Are the lenses at minimum aperture when removed from the body?
09-17-2012, 01:03 AM   #5
Yes they are on minimum. There is a DA-L 18-55 kit, and a 100-300 F5-6.3 Tamron telephoto lens. They are not stucked.
09-17-2012, 01:37 AM   #6
calsan's Avatar
How about resetting the custom function menu?
09-17-2012, 02:30 AM   #7
I will try it, when I go home.
09-17-2012, 10:38 PM   #8
Ok, I tried a menu reset. Same problem. But! If i set in the custom menu in "using aperture ring" point to Prohibited, the DA-L kit lens is not working too... So, the body knows the kit lens as a manual lens????
09-17-2012, 10:39 PM   #9
Tried a HSM lens on the body, thats works perfectly, as the manual lenses, but the screw drive af lenses not.
09-17-2012, 11:01 PM   #10
My K10D did that -- wouldn't stop down but once in a while it would. For instance if I put it on continuous shooting and set it for f8, I might get 4 blown out shots and one exposed correctly. But most of the time blown out. Optical preview was also hit-or-miss. Sent it to CRIS and got a new "aperture control block" for about $110 I think. Works perfectly now...
aperture, body, camera, k10d aperture control, pentax help
Using old Tamron SP 35-210 1:3,5-4.2 with K-5, aperture control ? karaff Pentax K-5 3 08-18-2012 04:55 AM
Z1 Aperture control wheel mzsaunders Pentax Film SLR Discussion 5 04-22-2012 11:14 AM
Movie Aperture Control - what is it!? vanakaru Video and Pentax HDSLRs 2 03-11-2011 03:32 AM
Loss of aperture control on K100D teamgs Pentax DSLR Discussion 4 09-25-2010 01:00 PM
K10d - Aperture Number error- JPEG/RAW najo Pentax DSLR Discussion 2 03-27-2009 03:52 PM
All times are GMT -7. The time now is 12:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
