09-18-2012, 04:33 PM   #1
ChooseAName's Avatar
Overexposing with external flash and manual lenses
Today I was taking pictures in a small bedroom (about 15ft x 15ft, with 8 ft ceiling) with K-x, M 85/2, and Metz 48 flash. The ISO was down as far as it could go (100), and the shutter speed was as high as it could go, 180. The lens was at 2.8 or 3.5. The flash was set to -3 EV and P, TTL, and HSS (but as I understand it, P-TTL doesn't work on manual lenses...?) I was still getting a large amount of blown highlights, as shown in the sample photo.
I guess technically the highlights might not be completely blown though, as I can recover a lot of the image in Lightroom, as seen in the not-so-overexposed attachment. To achieve that, I set the exposure slider to -4.0 and the Blacks to 45. The recovered version still looks a bit strange to my eyes, definitely not the way I saw the scene.
Is there some magical setting that I am totally missing, or is this something I'll just have to live with? i.e. recovering in LR and/or stopping down the lens (which I'd prefer not to do because I like a thin DOF most of the time)
PENTAX K-x  Photo
09-18-2012, 04:50 PM   #2
P-TTL does NOT work with manual lenses. Unless you're using the flash's auto mode (using the flash's own light sensor), the flash will fire at full power (or whatever power ratio it happens to be set to).
You'll have to use the manual flash mode: adjust ISO and aperture settings (and the flash's power ratio setting, if available) depending on the distance from the flash to the subject being photographed. It's not the end of the world, but it's clumsy, especially when you bounce the flash.
For this reason, I don't buy ANY flash that does not have auto mode.
09-18-2012, 05:04 PM   #3
QuoteOriginally posted by SOldBear Quote
Ah, well, that would definitely be the problem then. According to to Matt's Pentax flash site (Feature Tables - Pentax P-TTL Flash Comparison), the Metz-48 doesn't have auto mode. Any flashes that do are way out of my price range right now, so I'll just have to live with it. I do have an A 50/1.7 on the way though, so I believe P-TTL should work with that? Thanks for the answer, BTW.
09-18-2012, 05:15 PM   #4
QuoteOriginally posted by ChooseAName Quote
Yes it will.
09-18-2012, 06:21 PM   #5
Just1MoreDave's Avatar
You could use the manual power settings, 25 steps. A good starting point would be 1/16, since that's four stops down from the full setting.
09-18-2012, 08:06 PM   #6
aleonx3's Avatar
As expected since it will flash with full power, try M mode on the flash and start lowest setting.
09-18-2012, 11:12 PM   #7
As others has mentioned, reducing power from full to a lower setting would be required for close-ups like your sample picture. This should be done in conjunction with reading up in your manual the Guide Numbers for the flash (and making adjustments to this for the zoom setting of the flash if it has one).
Guideline numbers are a simple means of relating flash output to distance, aperture and ISO settings and a basic understanding of this is needed when going fully manual with flash use. As zoom settings on a flash either concentrate light or disperse it more widely, an appendix to your flash manual will probably have different guide number tables for each zoom setting. You would need to make your own adjustment to the Guide Number for any manually lowered power output eg halving, quartering the Guide Number as appropriate for the lowered power level. And Guide Numbers change for different ISO, so make sure the Guide Number used is appropriate for the ISO setting you're using on the camera.
This will allow you to determine the correct aperture setting for the combination of distance and power output. Required aperture equals Guide Number divided by distance (making sure distance is measured in units consistent with the Guideline Number (ie both either in metres or feet, not a mix!). Sounds a little complicated initially but isn't really once you get your head around it.
Note though that bounce flash or using clip on diffusers will lower what flash output reaches the subject. Use the manual's relevant guide number as a start and then experiment with how much you need to open up the lens aperture or increase ISO sensitivity to get correct exposure.
Shutter speed does not influence exposure levels with flash photography (unless you get slow enough that ambient light starts to dominate).
Unless you reduce power by quite some margin for the supplied sample shot, you will most likely need an aperture setting much smaller that F2.8 or 3.5. My rough guess is that your image would have been a lot better around f8 plus or minus.
09-19-2012, 05:25 AM   #8
Thanks for the advice, everyone. I thought that adjusting the EV values on the flash while in P-TTL would tone the flash power down even with a manual lens, but I take it that's not the case. I'll put the flash in M mode, adjust power down, and see what I get.
09-19-2012, 03:31 PM   #9
DaveHolmes's Avatar
Check out Zack Arias OneLight on youtube
Skip to 1:25... He clearly explains how to get proper exposure using manual flash in the full video... This is unfortunately is just a montage...
But essentially: Shutter controls Ambient light... Aperture controls Flash-Exposure - if you need to keep a specific aperture for DoF you need to mess with either your flash-power or your ISO or both...
09-20-2012, 05:43 AM   #10
Lowell Goudge's Avatar
it is unfortunate here no one has yet offered the calculation for manual flash.
your flash is given a guide number, usually expressed in meters for ISO 100.
Guide Number (GN) = Distance (D) x Aperture (A)
the on board flash , for example has a GN of typically between 13 and 16.
to make more use of the formula, consider the following modification and re-orginization of the formula
Aperture = Guide Number / Distance x Square root (ISO/100)
if you are for example at ISO 200 your guide number increases by 40% and at ISO 400 by a factor of 2.
With this formula, you can easily do manual flash calculations, and get within a half stop of perfect exposure,
consider a simple example, shooting at ISO 400 with the on board flash and a kit lens, and a subject at 3 meters (10 feet). The GN is between 26 and 32 (depending on camera model) for ISO 400 and with a distance of 3 meters(10 feet) your aperture would be roughly 30 / 3 = F10
pretty simple.change to ISO 100 and cut the guide number by 2 and you are now shooting at F5 or basically wide open. move in from 20 feet to 5 feet, while at ISO 100 and you are back to F10.
keep the formula handy it is simple to use and you can do the calculations in your head with just a little practice.
09-20-2012, 07:10 AM   #11
Actually I had. Third paragraph after I had first described where and what ChooseAName should look for to find the right Guide Numbers for his Metz flash.
09-20-2012, 09:03 AM   #12
QuoteOriginally posted by southlander Quote
except that you left out the compensation for ISO, as a general formula
09-20-2012, 06:53 PM   #13
True. But my intent was to guide ChooseAName towards his flash manual to look up GN's for different ISOs as a starting point for his exporation of manual flash usage. I normally fail miserably in following the KISS principle but on this occasion had decided to keep away from the maths involving squares and square roots. Also going to the manual would lead him to GN's for the zoom (lens focal length) settings available on his flash (if it has this feature) as ignoring the effect of zooming the flash output would lead to incorrect results.
09-24-2012, 09:00 AM   #14
JimJohnson's Avatar
See this post on how to shoot P-TTL with an M-series lens. It can be done. It may not be worth your effort, but it can be done.
camera, flash, lens, pentax help, photography
Definitive manual external flash guidance devorama Pentax Q 11 5 Days Ago 06:21 PM
I cant get my external flash to fire in manual mode dmbaile2 Pentax K-r 6 05-20-2012 02:29 AM
Flash with new manual lenses Urmas R. Flashes, Lighting, and Studio 4 04-28-2011 06:43 AM
vivitar flash with kr overexposing Classico Pentax K-r 23 04-28-2011 02:20 AM
K7 overexposing w/ Manual lenses??? JeremeyN Pentax DSLR Discussion 6 04-19-2010 06:22 PM
All times are GMT -7. The time now is 09:11 PM. | See also: NikonForums.com, part of our network of photo forums!
