09-20-2012, 07:37 PM   #1
Oily Blades!!
Hi
Their is a Lens on Ebay which i really want. My only concern is that the Lens does have a little oil on the Blades. Is this something I should be concerned about? Would this be a costly repair job?
09-20-2012, 07:45 PM   #2
pezmaker's Avatar
Whether or not it's something to be concerned about depends on the lens. If it's an older M42 lens with a preset aperture (so two rings to control aperture) or is an m42 and you're manually changing the aperture with the ring for shooting, then oily blades is just fine. I also have an m42 "auto" lens that has oil and it works just fine even on my spotmatic with auto. K mount lenses seem to be quite a bit more susceptible to negative results form oily blades. I'm unsure of any cost to get it done, and probably depends on the lens itself and who you have do the work.
09-20-2012, 08:35 PM   #3
Julie's Avatar
I have a Pentax A 50 2.8 Macro with some signs of oil on the blades and some very tiny scratches on the rear element- it seems to have very little/no noticeable effect on my photos, at least to my eyes.
I suppose I will send it to Eric someday and see how much work like this will run me, but at the moment, I'm using this lens quite a lot; hardly leaves my camera, I don't want to be without it.
09-21-2012, 05:39 AM   #4
The Lens is a F 50mm 1.7, "auto" lens from the 80's I believe.
09-21-2012, 06:46 AM   #5
DaveHolmes's Avatar
QuoteOriginally posted by Zedman Quote
There will be better copies up in time... Hold out for one of them...
09-21-2012, 07:30 AM   #6
pezmaker's Avatar
QuoteOriginally posted by DaveHolmes Quote
What Dave said
camera, lens, pentax help, photography
For Sale - Sold: Vivitar 70~210 2.8-4.0 "A" Series (V3.3 Komine) [oily blades] joe.penn Sold Items 0 09-05-2012 12:06 PM
HOW TO STORE LENS PROPERLY? (prevent fungus, oily blades, etc.) iNicole Pentax SLR Lens Discussion 6 08-20-2012 04:03 AM
Success - Oily Blades, Clean and Snappy MountainManJim Welcomes and Introductions 6 04-10-2011 09:01 PM
How to fix oily aperture blades madhurvyas Photographic Technique 5 03-30-2008 02:21 PM
How to fix Oily aperture blades madhurvyas Photographic Technique 0 03-12-2008 01:03 AM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, part of our network of photo forums!
