09-21-2012, 02:28 AM   #1
Miranda 28mm aperture failure
Hi!
Just got an used miranda 28mm 1:2.8 with a major problem.
With the lens unmounted the aperture blades works perfectly but when i mount it the aperture stucks wide open.
It seems like the aperture lever makes the lens stick in f:2,8.
Camera: K-5
Lens: Miranda 28mm 1:2.8 MC Miranda 28mm, f2.8 MC Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
The aperture lever of the miranda seems wider then the lever of a original pentax lens.
Would it help to remove the lever or what should i do?
09-21-2012, 04:57 AM   #2
Na Horuk's Avatar
What about stop down metering, does that work? I have a 50mm Miranda lens, and it often behaves in the same way. Although sometimes it behaves like a preset lens (where the aperture constantly stays at whatever you set the aperture ring), but more often it behaves as yours. I would also like a solution for this. Could the plastic mount (no contacts) be the problem?
09-21-2012, 07:43 AM   #3
I canīt even make it work lika a preset lens -.-
09-21-2012, 11:36 AM   #4
Na Horuk's Avatar
Btw, ff you unmount it, can you move the aperture lever normally?
09-21-2012, 12:02 PM   #5
Yes everthing works perfectly normal when it is unmounted
09-21-2012, 05:06 PM   #6
kcobain1992's Avatar
I don't know your background (if you have ever used other manual lenses on your K-5 and if they work OK), but here I go stating the obvious: 1) do you have "use aperture ring" enabled? 2) are you in Manual mode? (Av is NOT ok).
09-22-2012, 04:46 AM   #7
Thanks cobain, manual mode did work and yes this is my first manual lens.
When i use Av i still got exposure metering but the aperture it is locked to f:2.8. When i use manual mode i got no exposure metering at all, is it possible to have exposure metering on a manual lens?
09-22-2012, 05:10 AM   #8
You're welcome. In Av mode, you only get metering wide open, but you will have to dial some exposure compensation - +2 or in the ballpark. In manual mode, it's easier because you can just press the Av+/- button, or the green button. Press it before each shot and you should get good results.
09-22-2012, 07:13 AM   #9
Thanks again, it works great!
28mm, aperture, camera, lens, lever, mc, miranda, pentax, pentax help, photography
Vivitar 28mm F2 aperture blades zoeybird Pentax SLR Lens Discussion 38 01-08-2017 04:40 PM
K 28mm f3.5 aperture bearing Chaos_Realm Pentax SLR Lens Discussion 6 03-15-2012 06:51 PM
SMC 28mm f2.0 - aperture stuck. HELP! natedog23z Pentax SLR Lens Discussion 37 06-14-2010 04:45 PM
For Sale - Sold: SMC Pentax-A 50mm F1.4, Miranda Auto MC 28mm f2.8 [Worldwide] bodhi08 Sold Items 2 06-05-2010 10:32 PM
All times are GMT -7. The time now is 04:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
