Start up and Card Read Problems:Some Solutions
I thought I would pass on a couple of tips since I have gained so much from this and the other forum when confronting problems.
After buying a K-X my DS2 languished for several months unused. When I checked it out, I was getting a dead battery and no card indication. Cleaning contacts and new batteries did not help. On this forum I found advice to turn the camera on and off several times in rapid succession. This cleared up the battery problem. I assume there was some oxidation in the switch itself.
I was still getting a no card read. I dipped an SD card in alcohol, shook off some of the liquid and then inserted it twice in the camera. Voila, I was not getting a card read error. I assume there was some oxidation in the slot which I was able to remove. I probably should not have stored the camera with no SD card in it.
I now have my backup camera back and plan to use it on a more regular basis. Hope this helps someone.
