09-24-2012, 10:52 PM   #1
Shutter fires when using 50mm 1.4 Pentax M on KR
I have been using the 50mm 1.4 Pentax M M42 mount on my KR for the past 4 months without any problems but recently it started acting funny. The shutter fires whenever I press ANY button on the camera and it will keep on doing that until I use the 18-55 that came with it. Just want to ask if there is a fix for this. I normally use this lens more often than the 18-55 that came with it. I barely remove this from the camera. I followed every step in the article How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-5, K-r, K-x, K-7...). Im just wondering maybe it has something do with the adapter that I used. I got the Pentax M as a hand me down from my dad and the metal adapter I bought from Hidalgo Manila for about $10 .
09-24-2012, 11:09 PM   #2
twitch's Avatar
Oh dear, sounds like your camera might have developed the dreaded "mirror flop". Search for that phrase here or on google, there's a lot of info on it.
09-24-2012, 11:51 PM   #3
altopiet's Avatar
https://www.pentaxforums.com/forums/pentax-k-r/195457-mirror-flop-issue.html.
09-25-2012, 12:00 AM   #4
wow you guys work fast! will read this one =P
09-25-2012, 12:44 AM   #5
kcobain1992's Avatar
First of all, the Pentax M is not an M42 mount. Maybe you have a different lens?
Secondly, I'd appreciate a picture of the lens rear.
09-25-2012, 01:30 AM   #6
TZH
TZH's Avatar
My K-r is having the same problem ... I would like to use my K-x rather than K-r when metering a M.
09-25-2012, 04:32 AM   #7
altopiet's Avatar
QuoteOriginally posted by kcobain1992 Quote
You are right, a picture will help a lot. I think it might perhaps be a 1.4 Takumar, with a Pentax lens cap?
09-25-2012, 05:53 PM   #8
I checked it last night, found out that the mirror also flops when there is no lens on the cam. It only stops acting normal when i put in the kit lens. I'l take a picture of the lens maybe it is a tak.
50mm, 50mm 1.4 pentax, adapter, camera, fires, kr, m42, pentax, pentax help, shutter, shutter fires
Shutter fires in video mode dwsiii Pentax K-30 & K-50 24 08-09-2012 07:32 AM
shutter fires twice in single shot mode??? shang Pentax K-5 7 07-02-2012 11:26 PM
Pentax k5 with 50mm 1:1.7 and shutter speed smack1019 Pentax K-5 10 03-04-2012 03:52 PM
Original Pentax 645 only fires once in S mode then needs reboot Steinback Pentax Medium Format 3 01-22-2012 01:51 AM
Shutter only fires sometimes with manual lens - sears 50mm f1.7 jptruesdale Troubleshooting and Beginner Help 4 10-11-2011 08:16 AM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
