09-25-2012, 05:24 AM   #1
Spodeworld's Avatar
Focus Screen - is this a scratch?
Hi,
I tried to clean a focus screen recently using the detergent, distilled water, etc. method. After I put the screen back in (with some difficulty), I noticed what appears to be a threadlike thing on the right hand side of the split. I took the screen out and used a blower on it. No change. I was wondering if it looks like I might have damaged it. Does this appear to be a scratch?
Thanks
09-25-2012, 06:01 AM   #2
Pauld's Avatar
It looks like it's either a scratch or some water has been able to seep into the crease.
09-25-2012, 06:10 AM   #3
Spodeworld's Avatar
The procedure was done Saturday, and the pic was taken today. Wondering if water could still be a culprit at this point.
09-25-2012, 08:47 AM   #4
JohnBee's Avatar
Hi Spodworld,
Can you identify which highlighted area is subject to the inquiry?
09-25-2012, 08:53 AM   #5
JohnBee's Avatar
QuoteOriginally posted by Spodeworld Quote
I think he means a water stain.
Though in the end, if you noticed it prior too and after a wash then it's unlikely that its a water stain. Not saying it's impossible, though in most cases, a water stain will often disolve once the screen is submerged again. That being said, I think we could get a better look if you took a macro shot of the area and posted a 1:1 crop of that area?
Do you have a lens or adapter that can help do that? (Raynox, reversal ring, extension tube etc)
09-25-2012, 08:57 AM   #6
crewl1's Avatar
I have so much gunk on my focus screens, I just learn to look past them. It won't show up on your pictures.
Taking it out to try and clean it always seems to cause more problems than it fixes, IMO.
09-25-2012, 10:00 AM   #7
Spodeworld's Avatar
Thanks all for your feedback....
Hi John,
I was talking about the bottom item, at the right side of the split (but, while you on it, the upper one also showed up after the focus screen bath, and still remains too). It actually looks like a fairly sharp dark thread when it is clearer (if I could focus it better). I did use a macro lens (Tamron 60mm f2), but maybe I'll give it another try.
I did not notice it prior to washing.
After noticing it, I removed it again, didn't really see anything visually inspecting the screen, and tried using the blower.
That didn't seem to make a difference.
QuoteOriginally posted by JohnBee Quote
09-25-2012, 10:07 AM   #8
kcmadr's Avatar
QuoteOriginally posted by crewl1 Quote
Yes, you are corrrect.
I removed the focus screen on my K20D to remove an insolent speck of dust and scratched it. Then I had to buy a new focus screen because of the scratch and ended up scratching that upon installation. So I had to buy a new focus screen which I made damn sure of that everything went according to plan, which it did... finally.
09-25-2012, 11:23 AM   #9
Spodeworld's Avatar
Wow...that must have set you back a bit...esp if they were Katzeye or focusingscreen.com screens
QuoteOriginally posted by kcmadr Quote
09-25-2012, 01:05 PM   #10
kcmadr's Avatar
Any expense was unnecessary since it was out of stupidity in the first place. I took the opportunity to upgrade the focus screen from the basic K20D to the LL-80 Divided screen, and then had to replace that one. So it came to about $100... Luckily I just swallowed it and moved on. Haven't really played much with focussing screens since.
Life... and its experiences... :P
-Mike
09-14-2014, 10:37 AM   #11
Hi, can I know where did you buy your focusing screen? Thank you
09-14-2014, 01:47 PM   #12
QuoteOriginally posted by adawong Quote
Welcome to the Pentax Forums! You have revived a zombie thread.
There are a number of discussions on this site in regards to aftermarket screens and the plus and minus points of the various types. The main vendors in order of decreasing cost are:To get clarification on the individual types, I would suggest starting a new thread in the camera and field accessories section of this site:
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/
focus, focus screen, pentax help, screen
Focus screen (split screen) Johnthethird Visitors' Center 7 09-25-2012 05:01 AM
K-x focus screen drawing & Travor focus screen issue xjx Pentax DSLR and Camera Articles 2 06-06-2012 10:13 PM
Did I just scratch my VF screen? slr_neophyte Troubleshooting and Beginner Help 7 06-08-2011 08:02 PM
Focus Screen Tom S. Pentax K-5 25 12-20-2010 04:40 AM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
All times are GMT -7. The time now is 01:53 PM. | See also: NikonForums.com, part of our network of photo forums!
