09-27-2012, 11:16 PM   #1
Macro lens wont work
Oh dear i have dropped my pentax K200 camera and now my macro/normal 28-90 sigma lens won't work, have i completely damaged it? in the window it keeps showing me an F- -, and i cant take a picture at all nor will the button that turns to different exposures. any ideas.
If i put my spare Pentax 18-55 normal lens on i dont have any troubles.
Plus before i dropped it, my veiwing window (after photos have been taken) always seems to be whitish/hazy look, but when i put the sd card into computer the photos look great, any ideas why. I dont know what to do and i dont know why this is happening. " Not happy jan"
09-28-2012, 12:00 AM   #2
Kona's Avatar
F-- means it isn't reading the contacts properly, first port of call would be to try cleaning them. There are various methods recommended to do this (such as erasers for pencils and such) but I personally just use a bit of rubbing alcohol; hasn't failed me yet. Though a drop cause more serious issues.
Viewfinder being hazy, but photos being fine, is probably the mirror (or viewfinder itself) being dirty/smudged, or possibly even fungus. Try cleaning the mirror first and see if that gets you anywhere. Also, you say after photos have been taken... it's not just fogging up from you breathing on it while using it, is it? Just throwing that out there.
09-28-2012, 12:12 AM   #3
calsan's Avatar
QuoteOriginally posted by rosebud Quote
Do you mean the lcd display on the back???
09-28-2012, 12:28 AM   #4
Hi Kona, thanks for replying. I have checked the mirror al clean, and so if the view finder. The fogging no no heavy breathing causing it. Found that its usually the outside times that it does this.. Where about are the contacts. the lens or the camera... I have a terriable feeling that it maybe the lens problem. Have tried to see how it would cost to get another one and im astounded as to the pricing. Not sure what to do.
09-28-2012, 12:30 AM   #5
Hi Calsan, ahhhh thats whats it is called LCD display, yes thats it.
09-28-2012, 01:35 AM   #6
Kona's Avatar
The contacts are on both the lens and the camera, however if only one lens is giving F-- where another isn't, you want to clean the contacts on that lens (though doing all won't hurt).
It's the row of little metallic dots on the rim of the lens where it connects to the camera.
As for things looking hazy/white on the LCD, it could be highlights blowing out on the screen, but not on your monitor? I'm really not sure how good the screen is on the older bodies -- it also depends on your monitor, too.
But yes, worst case scenario, the lens is kaput and you may need another... they are very pricy new, but you can get some great bargains second hand, such as in the marketplace here. I've not bought a single lens new since I bought my camera, bought almost all of them from the marketplace here. You may also be able to get a much better lens in the process.
09-28-2012, 03:53 AM   #7
Na Horuk's Avatar
Does the lens AF normally? Do the aperture blades move as they should?
09-28-2012, 03:59 AM   #8
does this lens have a{A} setting if so make sure it has not move off that setting
09-28-2012, 07:44 AM   #9
TER-OR's Avatar
Hopefully Crash is right - and the aperture ring (if it has one) has moved off the A setting. If not, and it's all clean, then either the lens mount or the camera mount may have been damaged. I had a quick look for the lens on the database and didn't find it.
dont, ideas, lens, macro lens, pentax, pentax help, photos, window
CHEAP MACRO -- Buying or exploiting a lens for ultraclose work RioRico Pentax Lens Articles 13 04-22-2015 03:11 PM
IR remote wont work on K-01 slackercruster Pentax K-01 19 02-26-2013 05:59 AM
Best lens for floral work, macro? djc737 Pentax SLR Lens Discussion 20 05-22-2011 03:21 PM
Zenit 58mm fits but wont work? emmy957 Troubleshooting and Beginner Help 7 04-13-2011 06:02 AM
Why wont my lens work for my k2000 pgfilms Troubleshooting and Beginner Help 2 11-18-2010 07:46 PM
All times are GMT -7. The time now is 11:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
