09-30-2012, 12:09 PM   #1
Shake reduction
Reading the manual (K-30):
"The Shake Reduction function will not fully work when shooting with a very
slow shutter speed, for example when panning or capturing images of night
scenes. In this case, it is recommended to deactivate the Shake Reduction
function and use the camera with a tripod.
Is it really necessary to deactivate SR when using tripod, and why? I mean are there any downsides if you just leave it on?
09-30-2012, 12:20 PM   #2
SpecialK's Avatar
Yes. The SR mechanism will try to correct for non-existent movement.
09-30-2012, 12:20 PM   #3
Sagitta's Avatar
QuoteOriginally posted by drawbar Quote
function and use the camera with a tripod."
SR will ALWAYS try to engage, even if the camera is entirely stable. That means the sensor will shift, and you'll wind up with a less than optimal photo.
09-30-2012, 12:49 PM   #4
demp10's Avatar
If you use a very light and unstable tripod then leave it ON. On a better tripod always turn it OFF. Even better, use the 2s delay that automatically turns SR OFF and waits 2 secs before firing the shutter, giving the entire system a little time to stabilize from vibrations. A remote release (wired, IR or remote trigger) can help even more especially with longer focal lengths.
The SR system was designed to correct handheld (or monopod) movements like up-down, left-right shifts and rotations. When on a stable tripod, if there is any residual movement from wind or vibrations, it will have very different signature form handheld. The SR system will try to correct it assuming handheld and the results will be worse.
09-30-2012, 01:34 PM   #5
Moderator PEG Judges
Kerrowdown's Avatar
Yep, it's like they all said, I never seem to get to threads where I do know the answer (that's not often) quick enough to be the first correct reply.
09-30-2012, 02:09 PM   #6
QuoteOriginally posted by demp10 Quote
Are you pretty certain it's better to use SR on a monopod? Since I haven't used my monopod much (but anticipate I will be in the near future) I've never tested this. I'd always assumed monopod movement would we too dissimilar from handheld.
09-30-2012, 03:41 PM   #7
Kerrowdown's Avatar
In use a Manfrotto 680B monopod with a 234 head and I always turn off the SR same as I would for tripod. Monopods tend to be pretty stable when used correctly, but give it a whirl for yourself and see how you get on.
09-30-2012, 05:02 PM   #8
patrick9's Avatar
I look forward to the day when I will need to turn off SR for a tripod
09-30-2012, 08:35 PM   #9
demp10's Avatar
QuoteOriginally posted by DSims Quote
Well, nothing is certain, but a monopod will basically prevent up and down motion only. You can still move the entire system left and right in a slight orbital motion. This motion is similar to handheld with the up/down component removed, so it should benefit from SR.
I always leave SR ON with my Manfrotto 679B monopod and I never noticed SR induced artifacts.
09-30-2012, 11:13 PM   #10
demp10:
"Even better, use the 2s delay that automatically turns SR OFF and waits 2 secs before firing the shutter, giving the entire system a little time to stabilize from vibrations."
Very good advice. Thanks!
camera, deactivate, function, pentax help, photography, reduction, shake
K5's Shake Reduction billylh Pentax K-5 30 07-21-2012 05:29 PM
shake reduction and tripod booboomissy Pentax K-5 9 07-18-2011 08:46 AM
Shake Reduction on or off? GoldenRGuy Pentax DSLR Discussion 7 02-16-2011 08:37 PM
K-x and K-r Shake Reduction performance chiquito3 Pentax DSLR Discussion 15 12-31-2010 09:54 AM
When to use Shake Reduction? Todd Adamson Troubleshooting and Beginner Help 9 11-04-2010 05:36 AM
All times are GMT -7. The time now is 07:49 PM. | See also: NikonForums.com, part of our network of photo forums!
