10-06-2012, 04:35 PM   #1
RockvilleBob's Avatar
Image Counter Problem I got a "-" in the sequence
The K-r uses the nomenclature IMGPnnnn,DNG to record images. I just shot a 1000+ exposure HDR Pano and my counter rolled over from IMPG9999.DNG to IMGP0001.DNG. BUT it also added three files with nomenclature IMGP001-1.DNG, IMGP0002-1.DNG, and IMPG0003-1.DNG. Because the photos are HDR sequences the order is important. These files appear not to be in order.
What does a file with a name IMGP0001-1.DNG mean? Where does it fit in the order of files shot? and how the heck did I make this mess?
Thanks for your help.
10-06-2012, 05:22 PM   #2
They're in the same folder, right? It could be that the camera did this to avoid overwriting other files. The true sequence number should be embedded in the EXIF
10-06-2012, 05:30 PM   #3
I think you may be right. I did get the correct sequence by using Bridge and Camera Raw to sort by date. The interesting thing is that the sequence was taken in order so somehow the three files out of hundreds I had with a dash in them were stored after three shots were taken after them by saved first. In other words the file with the dash was taken prior to the file without the dash.
The good news is that I solved the problem. I still cannot figure out what caused this to occur.
counter, files, hdr, nomenclature, pentax help, shot
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
"This image cannot be displayed" problem with K5 sb in ak Troubleshooting and Beginner Help 6 06-14-2012 10:08 PM
"Attached Image" Width Overrides Personal Options Mike Cash Site Suggestions and Help 12 03-13-2011 09:09 PM
K5 - How do I access "Custom Image" to change sharpness/saturation/contrast, etc ? Feudal1 Troubleshooting and Beginner Help 3 11-03-2010 06:38 AM
Is there "Shutter Releases Counter" for Pentax? D0ri Pentax DSLR Discussion 9 02-22-2009 03:11 PM
All times are GMT -7. The time now is 10:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
