10-07-2012, 08:52 AM   #1
dcpropilot's Avatar
Please Help!! Problem with DA 40mm F2.8 Limited
I can't figure this out... For some reason my DA 40 Limited is everexposing. I've narrowed it down to the lens. Based on the photos and the exif data, can someone help me figure out why this lens/camera combination is doing this? These photos were ta ken at within a few minutes of each other, with the DA 18-55mm being the correct exposure. Thank you...
smc PENTAX-DA 18-55mm F3.5-5.6 AL II
smc PENTAX-DA 40mm F2.8 Limited
10-07-2012, 09:03 AM   #2
VisualDarkness's Avatar
Is the aperture working and snappy? Test moving the lever on the back of the lens.
10-07-2012, 09:20 AM   #3
dcpropilot's Avatar
It appears to be snappy. Indoor photos seem to be less affected, but outdoor shots are way off.
10-07-2012, 09:23 AM   #4
dcpropilot's Avatar
One other thing...I tried live view mode and the exposure appears to be accurate in live view, but when the shot is taken, it reverts to being badly overexposed...
10-07-2012, 09:29 AM   #5
Fogel70's Avatar
Have you tried multisegment metering?
In the above shots, center weighted metering might be confused by the darker flag in the center of the frame.
10-07-2012, 09:49 AM   #6
dcpropilot's Avatar
I tried the different settings (spot, multi-segment, and center weighted, they all look like this:
10-07-2012, 10:16 AM - 1 Like   #7
jatrax's Avatar
Put the camera in manual. Try a shot at f/2.8 and whatever speed is required to center the meter. Now take a series of shots changing the aperture from f/2.8 to f/16 but not changing the speed.
If the aperture is working properly each successive picture should get darker. If they don't then the aperture lever is not working and the lens is always shooting wide open. The lever could be bent slightly and not engaging.
10-07-2012, 10:40 AM   #8
Docrwm's Avatar
Clean the contacts for the lens.
10-07-2012, 10:41 AM   #9
Canada_Rockies's Avatar
And check that the aperture lever is not bent so it does not meet the actuating lever in the camera body.
10-07-2012, 02:46 PM   #10
dcpropilot's Avatar
Looks like that may be what it was...the aperture level must have been bent....After the suggestion that a bent aperture could be the cause, I was able to push the lever ever so slightly and now I'm getting better results.
10-07-2012, 08:18 PM   #11
Glad to help.
18-55mm, 40mm, da, f2.8, figure, pentax help, pentax-da, photos, smc
For Sale - Sold: Pentax SMCP-DA 40mm f/2.8 Limited Series (Silver from Limited Edition K5) Stevizzy Sold Items 10 09-02-2012 01:50 PM
For Sale - Sold: White K-x and 18-55mm, DA 40mm Limited, DA 70mm Limited Jend Sold Items 6 03-10-2012 06:23 PM
DA* 50-135 or 70mm limited and 40mm limited freewheelin25 Pentax SLR Lens Discussion 22 11-08-2011 03:53 AM
For Sale - Sold: DA 21mm limited, DA 40mm limited, DA* 16-50mm, DA* 50-135mm kphelan Sold Items 13 05-24-2011 02:47 PM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
