Originally posted by westmill Those little red squares are not the actual focus points. More of an indicator. The actual focus points are far far larger. The center focus point stretches out to the () spot metering markings which you can use quite accurately as a focus point.
he, he, yeah a few years ago I did a test of where the focus areas where. The areas were not at all what I had expected.
Just take a sheet of paper with a clear black dot on it, put your camera in continuous auto focus and move the dot around. You'll be able to determine where the edges of the focus "points" are.
One of my camera's focus points were mis-aligned such that all focus areas were down and left of center.
This helped me find the actual center spot. Sort of a pain in the arse kludge but I did not have to send the camera in for repair and be without it for 8-12 weeks. :-)
