10-13-2012, 01:31 PM   #1
slip's Avatar
Quantum Battery plus 1 pack problem
I bought a Vivitar 283 with a quantum battery pack (battery +1)
I have a flashing green light...when being charged yellow light and red light also on
I measured 6.5 volts at the battery adapter (module?) that fits in my vivitar 283. (it is rated for 6 volts)
When I unplug the charger the same place readers 1.5 volts no lights remain on.
The strange thing is, with or without the charger plugged into the unit, across the actual battery in the pack it only reads 1.5 volts
is there a reset procedure to fix this?
10-14-2012, 07:09 PM   #2
I bet you it's time to recell the unit.
But IMBO, Quantum Battery 1 or 1+ (or all low voltage packs) is not worth the trouble. It gives you more flashes per charge, but does not improve recycle time compared to 4 AA Eneloop cells.
Quantum Turbo (high voltage pack), on the other hand.....
10-15-2012, 04:12 AM   #3
slip's Avatar
QuoteOriginally posted by SOldBear Quote
thanks!
I thought it might need a new one... less then 20 dollars for one, dead simple to install... likely save some $ if the recycle time is the same
turbo would likely blow my 283-85 right up!
thanks again
randy
battery, charger, light, pack, pentax help, quantum, vivitar, volts
For Sale - Sold: k10D, w/kit lens, battery pack, extra battery. Orignal box. 4400 actuations. rangerbob36 Sold Items 5 09-15-2012 06:49 PM
Sunpak 433D and Quantum Battery 2 furryurry Flashes, Lighting, and Studio 2 04-23-2012 11:44 PM
AF-540FGZ Flash & Quantum Turbo battery Dreamsandmemories Flashes, Lighting, and Studio 3 12-20-2011 03:37 PM
For Sale - Sold: Camera, cable release, battery grip, flash, battery pack, 3 lenses and radio t WMBP Sold Items 20 07-15-2011 09:12 AM
For Sale - Sold: 2 Nikon sb28 flashes + Quantum Battery Pack (Worldwide) superbass Sold Items 8 10-15-2010 09:51 AM
All times are GMT -7. The time now is 08:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
