Originally posted by ajaya yes i was using built in flash with exposure +1 on AV mode
ok i will try to reduce and see how it will change the Image !
Thanks for the tip.
Hmm.... I'm thinking that you're getting confused on the +1 EV compensation and AV mode.
On AV mode, when you dial in +1 EV compensation, it means you are requesting for +1 stop of ambient exposure.
What i mean for the EV compensation is for flash. Look at your Kr and its 4-way button. The bottom one is for flash.
Select that and use the dial to see that the flash EV compensation will be changed within the range of -2 to +1.
That's why i advised you to shoot in manual.
When using flash, you are basically required to expose for TWO separate things.
1)Ambient: General exposure of the picture
2)Subject: Exposure of the subject with flash here
Therefore, have a practice now.
1) Switch to M mode and meter for a scene, including subject smack in the center. (make sure it meters 0.0)
2) Use flash and set the flash EV compensation to 0.0
3) take a picture
Then now,
1a) adjust in step 1 and expose the same scene with the EV metering showing -1.0
2a) dial in FLASH EV compensation to +1.0
3a) take a picture
You will notice now that the subject will be brighter than the background. You can practice outside and play around with the two DIFFERENT EV compensation;
flash EV compensation for subject, and
general EV compensation for ambient.
Adjust to suit to taste.
Get what i mean?
