10-26-2012, 10:03 AM   #1
Pentax k-5 iso issue
Hi guys!
I am relatively new to Pentax. Recently I noticed that my k-5 does not go lower than iso 200 with normal iso setting and 160 in extended sensitivity setting.
Maybe this is just a simple setting but I cannot find the solution.
Any advice is welcome.
Thanks a lot.
10-26-2012, 10:22 AM   #2
Roob-N-Boots's Avatar
I think you need to download the latest firmware. Latest K-5 Firmware Update : Software Downloads | PENTAX RICOH IMAGING
10-26-2012, 10:23 AM   #3
aurele's Avatar
no, just press the "info" button and desactivate the higlight / shadow compensation.
10-26-2012, 10:23 AM   #4
boriscleto's Avatar
Turn off Highlight and/or Shadow Correction in D-Range Setting.
10-26-2012, 10:23 AM   #5
blackcloudbrew's Avatar
It goes to 100 or 80 on extended sensitivity setting. You've got either the highlight or shadow correction set (record menu 3 Dynamic Range). When set the minimum ISO goes to 200 and 160 respectively. Turn off both of those and your ISO will behave as expected.
10-26-2012, 10:25 AM   #6
Thank you very much guys for responding this fast. The highlight correction was the "problem".
Thanks again.
10-27-2012, 03:48 AM   #7
Thanks from me too I just came in to ask about the same problem on my k-r
iso, k-5, pentax, pentax help
I am getting a lot of noise at ISO 800 and ISO 1600.... Abstract Pentax K-5 19 11-30-2010 10:48 AM
K-r vs. K-x ISO samples (or return of the ISO flower!) devorama Pentax K-r 31 10-29-2010 02:05 AM
K-x Av with auto-ISO: slow shutter speed issue Karellen Pentax DSLR Discussion 6 02-22-2010 03:58 PM
New k20d owner with low ISO noise issue candgpics Pentax DSLR Discussion 31 02-26-2009 08:56 AM
K100D shooting ISO 1600 issue: Images have orange horizontal streak kveldalf Pentax DSLR Discussion 8 11-02-2008 05:39 AM
All times are GMT -7. The time now is 07:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
