10-28-2012, 09:34 AM   #1
Pentax P30 - Wind Lever Problem.
Hi I picked up a Pentax P30 not too long ago from a camera fair and have just decided to give a test run. I popped some batteries in it earlier today and wound back the lever and pressed the shutter release button. It clicked but only once and now when I look through the viewfinder it's all black, except for a flashing M, number (dependent on what shutter speed it's on) and the number 1.
I've never used it before and it didn't have film in it. I was just wondering if anyone knows what going on or could help me?!
Thank you!
10-28-2012, 01:06 PM   #2
Swift1's Avatar
Sounds like the mirror is stuck or the shutter is stuck which will keep the mirror from returning.
If you remove lens, can you see the shutter?
If so, very gently, using a fingernail on the edge of the mirror, pull it downwards. If it moves freely, it's probably a shutter issue. If it feels stuck/sticking, it could be that the mirror has stuck to deteiorated mirror bumper foam.
Do not touch the reflective surface of the mirror or the focusing screen.
10-28-2012, 04:29 PM   #3
Just1MoreDave's Avatar
You may also have some luck taking off the bottom plate, I think only three screws. It gives you access to some of the mechanisms for cocking and firing. I have photos I took of a P3n for a different problem - the winding lever would not cock the shutter. Maybe not that helpful for your problem.
10-28-2012, 06:43 PM   #4
Thank you both for replying!
Swift1 - It moves freely, so is there anyway I could sort this out without taking it to a repair shop?
camera, lever, p30, pentax, pentax help, photography, shutter
P30 Wind Lever Doesn't Wind Complete Cycle - Any ideas? pengam Pentax Film SLR Discussion 14 08-31-2015 06:08 AM
ME super wind lever problem Cat among the pigeon Pentax Film SLR Discussion 11 07-14-2015 06:28 PM
k1000 wind lever... jseverson218 Pentax Film SLR Discussion 7 06-08-2012 02:33 PM
6x7II Film Advance Lever Wont Wind adprousa Pentax Medium Format 2 03-08-2011 07:43 AM
Pentax ME Super - Aperture Lever Problem ioszhka Pentax Film SLR Discussion 9 02-10-2011 03:30 AM
All times are GMT -7. The time now is 09:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
