Originally posted by vzbx Yes... and no I think. Maybe someone with a better knowledge of how WB works can correct me if I'm wrong, but AWB still allows you to see the colors changing, it's just that the camera proprely balances them so that you picture doesn't appear yellowish, or blueish etc.
Well, the WB setting is a single parameter, it doesn't treat different parts of the image independently. Auto white balance just sets that number for you. With a time lapse that included a sunrise or sunset, I'd *want* that blue or orange cast over those parts of the resulting video as contrast to the "neutral" daytime stuff, whereas with a single image maybe I would and maybe I wouldn't depending on what effect I was trying to achieve.
Quote: I think in this case what happened is that with little ambient light, such as in the pictures above, the camera had trouble finding the right WB and was applying a different one with almost every shot. Sunlight reflection on the clouds could also have played a part as someone mentioned before. So far that's the only logical explanation that I can come up with.
Yes, that's right -- if you check the WB parameter on those shots, you'll find they are all different, which doesn't work when you put the images together in a video. It is fixable if you shoot RAW -- you can set them all to the same thing later. But best just to put it on a neutral daytime setting that you expect will be right for most of the video and then let the sunrise and setset go ahead and have a cast which will look fine in a time-lapse -- it actually looks weird without it.
