10-31-2012, 06:03 AM   #1
Nikon FF body, Pentax lenses
Hi Guys,
I am considering purchasing the Nikon D600 which is a FF camera. I was wondering if it would be possible to use Pentax lenses (Taks, M, DA, etc) on that body. Does a good, reliable adapter exist attaching the lenses on the Nikon body? I am told that all Pentax lenses will become manual, but do not know if it is true. Has anyone tried it or have any experience using that combination, than please share. Thanks.
10-31-2012, 06:21 AM   #2
boriscleto's Avatar
Pentax lenses will not have infinity focus unless you use an optically corrected adapter. It will act like a short tele-converter and image quality will be reduced. All lenses become manual only, and DA lenses, lacking an aperture ring, would have no aperture control. In addition, DA lenses will not cover the FF sensor, you would have vignetting from most.
10-31-2012, 06:26 AM - 1 Like   #3
Clavius's Avatar
Placing them on a Canon body works like a charm though. The adapter from PK to Canon are without glass because of Canon's shorter registry distance.
10-31-2012, 06:35 AM   #4
Thanks Boriscleto. That doesn't sound good news for my pentax lenses
Thanks Clavius. Than perhaps a Canon FF. Have you purchased the adapter for a Canon FF body, for eg. like the 5D Mark II ? Where did you purchase it from? Will the Pentax DA's become manual lenses on a Canon FF body too?
10-31-2012, 06:38 AM   #5
boriscleto's Avatar
QuoteOriginally posted by voyager13 Quote
Yes, DA's become manual lenses on a Canon FF body and lack aperture control. You also have to remove the aperture lever to prevent it from hitting the mirror on a Canon FF body, or you can shave down the mirror.
10-31-2012, 06:50 AM   #6
That's bad news again for my Pentax lenses. Than I have two choices, either to buy into a new system completely, or wait for the jokers at Pentax to bring out an FF. Pentax lenses are too good to let go, hence I guess I will have to wait and hope.
10-31-2012, 06:51 AM   #7
Clavius's Avatar
I just purchased the cheapest Chinese version I could find on ebay, and it works fine.
Yes, they all become manual. And, with DA's, you'll have no control over the aperture, because of the lacking aperture ring.
10-31-2012, 07:05 AM   #8
QuoteOriginally posted by Clavius Quote
Than how do you figure out the DOF, does it become a trial and error experience? I don't understand. If you cannot control the aperture, how will you take sharp photos?
10-31-2012, 07:19 AM   #9
Clavius's Avatar
I don't use DA's on my Canon. Only Pentax lenses with an aperture ring. DA's don't cover FF anyway, so why bother?
10-31-2012, 07:19 AM   #10
JimJohnson's Avatar
With a DA lens there would be NO aperture control. Further, you will have only one aperture - wide open*. Further again, only a few DA lens are suitable for full-frame use - with most you will either get vignetting or unacceptable aberrations at the frame edges. *the only other way to adjust the aperture would be to manually move the aperture lever while the lens is unmounted and somehow clamp it in the desired position - and the only way to get consistency would be to etch your own scale on the lens next to the lever.
I'm sure some optics hobbyist would find this an exciting challenge. As for me, I think it would be a better use of my time and money to go find a different lens. Or, seriously question my need for a full frame body.
10-31-2012, 07:50 AM   #11
Here are the general guidelines:
Nikon: Backward compatible with most F-mount glass and not much else.
Pentax: Backward compatible with most K-mount and M42 glass and not much else
Canon EOS: No Canon backward compatibility, amazingly compatible with lenses made for many other mounts. As noted above, adapted lenses must have an aperture ring and there is also the issue of lack of mirror clearance for K-mount lenses on FF Canon bodies. This problem does not exist for M42 screwmount lenses.
10-31-2012, 07:57 AM   #12
Clavius's Avatar
This is not much of a problem, as the aperture lever is easily removed.
10-31-2012, 07:58 AM   #13
boriscleto's Avatar
You forgot Olympus OM with mount replacement, Contax/Yashica C/Y mount with mount replacement, and Leica R with mount replacement. Pre-AI F mount lenses will force fit without modification.
10-31-2012, 08:31 AM   #14
Tamron Adaptall SP lenses, work great on the Nikon. Just as well as the Nikon lenses but easier to find and much cheaper.
10-31-2012, 08:35 AM   #15
Miguel's Avatar
[deleted]
Actually some M42 lenses have clearance issues at least on a 5D; the same in my experience applies to a 5DMK2. Cannot speak to the 6D. . .
M
body, camera, ff, lenses, nikon, nikon ff, pentax, pentax help, photography
Fitting Nikon lenses on Pentax body minahasa Pentax SLR Lens Discussion 10 05-30-2014 07:13 AM
Can Nikon lenses be adapted to Pentax? slackercruster Pentax SLR Lens Discussion 15 04-17-2012 05:05 AM
Is in-body SR worth the switch from Nikon to Pentax for low light? nsfx Pentax K-5 72 12-16-2010 07:31 AM
using Canon/Nikon lenses with Pentax body? WMBP Pentax SLR Lens Discussion 27 09-17-2010 10:34 PM
Nikon lens on Pentax body? Scott_the_Artist Troubleshooting and Beginner Help 9 08-05-2009 07:05 AM
All times are GMT -7. The time now is 06:02 AM. | See also: NikonForums.com, part of our network of photo forums!
