Originally posted by amoringello My only concern would be if any of the pins should match those on the hotshoe.
It might be best to put some tape over all contact except the center spot. (This is pretty much a standard for the main firing pin.)
No need for tape to cover the contacts.
My friend is a Canon guy (30D and then 7D I think). He uses my flash units (Pentax and non-Pentax, see last line in my signature) AS IS all the times.
The problem, as stated in some posts above, is that you have to use the said Pentax flash in manual mode. There is no whaterver-TTL nor auto.
